Turn Signal Relocation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 01-20-2006, 08:44 AM Thread Starter
A VROC member asked me in my private e-mail how I did my rear TS relocation shown in my post #36662. Well, Vince , it was pretty simple. I removed the rear turn signal units from their original locations by removing the hold down bolts and disconnecting the electrical connections. The turn signal units have a knob (for lack of a better name) sticking out the bottom of them. I cut these off using my Dremel tool. I removed the tail light assembly, drilled a hole on the left and right sides of it to match the original hold down bolt size. I then used the original TS bolts to secure the TS units to the tail light unit. I had to splice the TS wires because the relocation left them a little too short. I hope this explains things
Vulcan Verses is offline
Closed Thread
You may not post new threads
You may not post replies
