Temperature Sensor - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 01-19-2006, 11:03 PM Thread Starter
Temperature Sensor
Does anybody have a temperature sensor to fit my 86 VN750? Mine
went South today.
Yes, part number 27101. RonAyers did not have it.
It is such a simple part, no moving parts. I think I will tinker
around with it before I declare it dead. It may well be that it has
just lost it's grounding through the radiator. I will try clamping
a solid ground to it tomorrow.
Ok, looking over the parts diagragm, I'm confused.. are you talking
about 92066-1183 PLUG,SENSOR WATER that sits on the thermostat
housing? (If so, Ron Ayers has it for $27.60)
The sensor I am referring to fits in the bottom of the radiator, on
the left side. I am not sure what the sensor on the thermostat is.
When I realized that my fan was not working I disconnected the wire
going to the sensor in the radiator and grounded it to the frame.
The fan started to work. I connected a hot test light to the
sensor, and nothing happened. So, I am pretty sure that is the
problem area.
Right, the complete number is
Part Number: 27010-1167
Description: SWITCH,FAN
Price: $57.68
There's more to that part number. It should be 5 digits, a dash, and 5
more digits to be a complete part number. Ron Ayers is a Kawasaki
dealer. They will have it or can order it for you.
Vulcan Verses is offline
Closed Thread
You may not post new threads
You may not post replies
