my 05 VN is bogging out - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 06-06-2014, 12:24 PM Thread Starter
Cool my 05 VN is bogging out
Bought my 05 with only 4500mls on it 3 weeks ago,,,was running great,,last night took it out and was bogging out in lower gears when I wasn't hitting the throttle hard,,when my throttle was only slightly on it bogged out,,choked,,any idea's?
JamesVerner is offline
post #2 of 5 (permalink) Old 06-06-2014, 12:39 PM
1987 Vulan VN750-A
ro35647's Avatar
I had that problem with mine too. My problem was caused by the vent hose on the right side air cleaner. It comes from the middle of the carburetors, and comes out by the right side air cleaner, mine was completely out sitting loose, but some people pinch them when they take off the tank. If you look at the back of the air cleaner, there's a hole at the rear of the air cleaner, you just shove it in there till it stops, then pull it out about an inch or so.
ro35647 is offline
post #3 of 5 (permalink) Old 06-06-2014, 01:05 PM
Mcneuby's Avatar
Bogging down
It could be the vent hose. Make sure it is routed properly and when you put it on the air cleaner , cut the end at a 45 degree angle to keep it from bottoming out. If it is already connected to the ear cut it at an angle, your problem might be that it is bottoming out.
Ride Safe
Mcneuby
New to me 2004 15k Last liscened in 2011. Stock as they come.
Mcneuby is offline
post #4 of 5 (permalink) Old 06-07-2014, 07:51 AM
Mcneuby's Avatar
Bogging Down
Another thing you could try would be to run Sea Foam through it. A couple tanks of fuel with a strong dose of Sea Foam has worked wonders for me.
Mcneuby
Mcneuby is offline
post #5 of 5 (permalink) Old 06-07-2014, 10:12 AM
Mcneuby
It's always worth a try. I pop Seafoam in every 2-3 full tanks to keep things clean.
