Hi there - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 07-02-2012, 03:59 PM Thread Starter
Hi there
Hi guys, I'm new to the Vulcan and when I say new I mean new. I just pick up a 1993 750 yesterday. Hope to have some fun with you guys!
NV Hunter is offline
post #2 of 5 (permalink) Old 07-02-2012, 04:08 PM
Welcome! Here's my new-owners checklist.
General
Inspect the tires for air, age and wear. Replace if they are too old, or too worn.
Perform an oil-change.
Inspect all fluid levels. Top up where needed.
Inspect all cables. Lube and replace where needed.
Inspect the brake's wear. Replace if too worn.
Inspect the fork seals and oil. Replace as necessary.
VN750 Specific
Inspect, and lube the drive-shaft splines. Moly 60 or better is suggested.
Replace your battery with an AGM or Gel style battery.
Replace your spark plugs with NGK Iridium Plugs #7803/DPR7EIX-9
Replace the stock Automatic Cam Chain Tensioners with Manual Cam Chain Tensioners, such as the ones manufactured by TOC.
Perform an rear-end oil-change.
Buy some SeaFoam, and use in every few tanks. If you are worried about the carbs being gummed up, you can drain some directly into the carbs via the vent hose.
Inspect the charging system on the bike. The stator is known to fail, which can cause the R/R to fail as well.
post #3 of 5 (permalink) Old 07-02-2012, 04:15 PM Thread Starter
Thanks for that list. We did almost all of that yesterday once we got home, no oil change. I must say this bike is fun to ride, my experance is with enduros and sport bikes.
post #4 of 5 (permalink) Old 07-02-2012, 11:39 PM
Welcome to the Vulcan madness!
post #5 of 5 (permalink) Old 07-03-2012, 12:59 AM
Welcome Hunter, What kind of Hunting do you do?
