Helppppp!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 05-29-2012, 12:09 PM Thread Starter
Helppppp!!!!!!
I put my bike in the shop(Best line Kawasaki,Boalsburg PA) to have a spring tune up done.Bike is running like a 50CC now and looking for help.
leester480 is offline
post #2 of 10 (permalink) Old 05-29-2012, 12:24 PM
So when you got the bike back from the shop, it's running bad? Is that something they'll warranty?
First, and foremost, check all electrical connections, especially the grounds.
Please describe everything you can, other than the loss of power. Is there backfiring? Hard starting?
post #3 of 10 (permalink) Old 05-29-2012, 12:25 PM
Check your coil connections. The small wires.
post #4 of 10 (permalink) Old 05-29-2012, 12:45 PM
Deviate's Avatar
Also, what did the shop say they fixed/serviced/adjusted? Maybe that can help pinpoint something they messed with or didn't put back correctly when they were done. And I would have to think they would fix it to your satisfaction if it was running fine when it went in but not when it came out.
Deviate is offline
post #5 of 10 (permalink) Old 05-29-2012, 01:49 PM
Gemguy's Avatar
Check to make sure the plug wires are plugged in all the way on both sides
~VROC~ # 389
Gemguy is offline
post #6 of 10 (permalink) Old 05-29-2012, 02:01 PM Thread Starter
no back firing,just found out that 1 pipe is running cooler than the other 3,runs fine at lower idle speed,no power for instance when you go up a hill, and when pulling off a stop light less power is available than when I put it in the shop.They've synch'd the carbs at idle and rev'd it checking synch.They've checked all the plugs,Cleaned the carbs,changed oil and plugs as part of maintenance.
post #7 of 10 (permalink) Old 05-29-2012, 02:02 PM Thread Starter
Didn't say a word about charging me for the issue.
post #8 of 10 (permalink) Old 05-29-2012, 02:35 PM
Papa Smurf's Avatar
Sure this is a Vulcan? You should only have 2 pipes. Also, if it is acting up, and they worked on it, they should fix everything. Other than that- I agree with checking your grounds.
Papa Smurf is offline
post #9 of 10 (permalink) Old 05-29-2012, 02:45 PM Thread Starter
sorry 1 pipe running hotter than other pipe
post #10 of 10 (permalink) Old 05-29-2012, 03:46 PM
Gemguy's Avatar
Are you sure you're getting ignition in the cylinder with the cooler pipe?
~VROC~ # 389
Gemguy is offline
