technical data - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 05-17-2012, 10:33 AM Thread Starter
technical data
Hi.I live in Germany and have a vulcan 750 from 1992.Its an american model imported back then into holland.The German authorities are very stringent with their registering system.I need a technical data sheet for the motorcycle with stuff like Hosepower, Noise levels, and so on.Does anyone know where I can get an official Kawasaki document with such info?Would be a great help.
gary-leon is offline
post #2 of 4 (permalink) Old 05-17-2012, 10:41 AM
Hi down load the Kawa free manual it will have all you need in there,
Have a look at this link. https://www.vn750.com/forum/showthread.php?t=3237
Swagman is offline
post #3 of 4 (permalink) Old 05-17-2012, 10:48 AM
As stated above, you can most likely use the spec sheet in the manual. If they require a legitimate printed copy, then you can probably pick up the manual used online for fairly cheap. I got my physical copy for $20 in the US.
post #4 of 4 (permalink) Old 05-17-2012, 10:54 AM
JM2001's Avatar
Hope this helps
http://www.motorbikes.be/en/Kawasaki...lcan_1992.aspx
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
Tags
information , technical data
