Please help 1995 vulcan 750 probléms - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 05-07-2012, 02:55 PM Thread Starter
Angry Please help 1995 vulcan 750 probléms
This is my first post on the forum. i have a 1995 Vulcan 750 that needs to be rebirthed. bought new sprk plugs and ignt coil seems fine.bought a new battery thas good to go. i cleaned the rusty gas tank and filled with gas and the petcock was leaking from the switch, and no matter weither the switch was on off or on res it kept coming out of the two forks the go to the carbs.Why? do i need a new petcock, rebuild kit, or the 5 hole o ring inside it does have some wear and tear and has crack on the inside hole to one outside hole. I jus shifted the position but still leaks and keeps pouring out uncontrolably.What should i do. My 2nd problem is if i should have to clean the carbs how do i take it off.i need instructions with pics and a diagram for. i also need the diagram or instructions with pics on how to connect the petcock back. it has three connections the two forks go to the carbs and the other 1 goes were i cant find the vacume hose or connection. how do i take carb off to clean pics and details. HELP
newrider2012 is offline
post #2 of 8 (permalink) Old 05-07-2012, 03:09 PM
Check out my page on Carbs here for the removal and installation instructions.
The hoses are fairly self explanatory. The petcock has 1 vacuum line (smaller) and two fuel lines. There is a set of lines that go to a T and into the right ear. Take note of these.
post #3 of 8 (permalink) Old 05-07-2012, 03:24 PM Thread Starter
RE: reply
What about the petcock is it suppose to do that how can i fix repair or do i have to replace
post #4 of 8 (permalink) Old 05-07-2012, 03:27 PM
romeobravo172
romeobravo172's Avatar
Tanner, isn't there another that connects on the rear side of right carb and goes back under seat to that valve coming off the reed valves? (Think that is what it is) Second ? why would anyone block that paticular one off with a screw in that line???
romeobravo172 is offline
post #5 of 8 (permalink) Old 05-07-2012, 03:30 PM
Sounds like you need a rebuild kit. Cheap on eBay.
The right vacuum line goes to the emissions system, which is often removed in an act called Coastering. You block it off after you remove the reed valve/emissions control system.
post #6 of 8 (permalink) Old 05-07-2012, 04:32 PM
ifixf18s's Avatar
Just a little bit of information I havent seen mentioned yet. The vacuume line that goes to petcock kind of acts like a switch to turn the fuel on and off. When theres vacuume on the vacuume line (engine running) it turns on the fuel. No vacuume, turns off the fuel.
ifixf18s is offline
post #7 of 8 (permalink) Old 05-07-2012, 04:44 PM
thtanner knows alot he helped me a bunch with diaging my bike
I'm still in search of a set of carbs due to my own stupidity but everything els worked out well
Plus check out the mod for the coils it sends alot more power to them and even if you dont need it right now it can only help
post #8 of 8 (permalink) Old 05-09-2012, 01:28 AM Thread Starter
I orded a new pet cock today i meant the petcock didnt stop i didnt have it connected when it was turned off and it poured the gas bad no control or do i need to connect it back to the carbs first and post pics or links if you can on full rebuild from top to bottom mine as well im 19 with 24 hrs on hand i need to motivate you know all and any help and tips thank you
ps. its a 1995 vulcan 750 turns over but dosnt krank i just dont know why petcock leaks like that unplugged and i want to fully rebuild as money comes just change paint hlp and tips on sandblasting and mods are great to
