Forum N00b, Spaniard - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-18-2012, 11:17 AM Thread Starter
Spaniard's Avatar
Hello all,
I've had my '86 VN750 for about 3 years and I love it! It's my first bike and it has been very low maintenance and a lot of fun.
Little things are beginning to go wrong, though, so I wanted to join the forum for info and advice.
My major concern right now is a noise that sounds like it may be valve tap; seems like its coming from the top of the engine.
I look forward to cruising through the threads for service and maintenance nuggets!
Cheers,
Span
Spaniard is offline
post #2 of 9 (permalink) Old 03-18-2012, 11:43 AM
Hi and welcome to the forum, have a look at your ACCT could be cam chain noise http://www.google.com/url?q=http://w...t5PbMzCrGMapAg try this link
Swagman is offline
post #3 of 9 (permalink) Old 03-18-2012, 02:50 PM
Definitely sounds like those ACCTs are starting to fail. I would replace them with MCCTs (TOC makes some good ones). Try the linked "Grambo fix" for a temporary solution to help diagnose the cause.
post #4 of 9 (permalink) Old 03-18-2012, 09:16 PM
TOC link to MCCTs:
http://www.tocmanufacturing.com/Manu...nTensioner.htm
Oh and BTW, welcome to the Vulcan madness. Although if you have been riding the vn750 for 3 years, you know all about it!
post #5 of 9 (permalink) Old 03-19-2012, 12:04 PM
firemancc91's Avatar
Welcome to the forum friend.
Live Free, Ride Much My Friends
Charlie
85 VN700
"SERENITY"
Replaced crankshaft and rod bearings
coasterd
earshaved
degoated
sportster mufflers installed
To do
Repaint tank, frt fender, and side covers
add saddle bags
add luggage rack
firemancc91 is offline
post #6 of 9 (permalink) Old 03-19-2012, 06:17 PM
JM2001's Avatar
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #7 of 9 (permalink) Old 03-19-2012, 07:32 PM
Welcome. If it is the cam chain tensioners, you need to do something about it quickly, before it causes a lot of internal engine damage. Do the Grambo trick, if that quiets it down, then go ahead and order the TOC manual tensioners. I have had them for over 40,000 miles, they are without a doubt the best thing I've ever done for my bike.
Couldn't help but notice, ANOTHER 1986. It is hard to believe how many 1986 models they made compared to other years, and how long they have survived. The '86 models must have been the best year for the VN750, I have an '02, and I doubt there will be any of them still around after that long. My '02 developed cam chain tensioner problems in less than 15,000 miles.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #8 of 9 (permalink) Old 03-20-2012, 08:02 PM
Calif Rider
weh44att's Avatar
Search the threds and read about how you can convert ACCT's to MCCT's for very
little money out of your pocket. I did mime over 15,000 miles ago and they are still going strong. With the right metric bolts and lock nuts and some rubber wachers they
can easily be converted. All this can be done for under 10.00 dollors. Check it out.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #9 of 9 (permalink) Old 03-23-2012, 07:03 PM Thread Starter
Spaniard's Avatar
Thanks for welcome!
Thanks everyone for the warm welcome and great advice!
I will research the linked info and see if this is something I think I can do myself. At first glance, the Grambo trick doesn't look too difficult, but I've known make a lot of simple jobs very complicated
And yes, am interested in a long-term fix, so I'll be looking into your suggestions about replacing my ACCTs.
Will post back my progress.
-span
Spaniard is offline
Tags
new user , valve tap
