tight downshifting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-14-2012, 10:17 PM Thread Starter
pittdave's Avatar
tight downshifting
Ive noticed from time to time that my downshifting to a stop is much tighter than the upshift while accel. Is this normal?? Its not all the time that I notice it
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 6 (permalink) Old 03-15-2012, 01:58 AM
Steve
350ernie2's Avatar
+1 I have the same issue.
Steve
VN750
KH500
Ducati 350sss
350ernie2 is offline
post #3 of 6 (permalink) Old 03-15-2012, 08:49 AM
Striker1's Avatar
If the speed isn't right mine will do that, but if I have the speed low enough It isn't a problem. Also check your oil. What type of oil are you using? What type of oil filter?
1986 Vulcan 750
30,000 miles and counting
Castrol GTX 10w-40
WIX- Gold oil filter Pt.#1356 @ Napa Auto supply $8.00
Seafoam-2 oz. to every other tank of gas @ Napa-$10
Yuasa M/F battery- YTX14AHL-BS
Lubed Splines- Moly EP Grease, 1lb. tub $3.49-Autozone Pt.#561753
Sprayed U-joint with Liquid Wrench White Lithium Grease- $3.99 Autozone Pt.# 828796
Castrol Hypoy C 80w90 Gear Oil $5.99- Autozone Pt.#991558
NGK Iridium IX Spark Plugs, $8.99(x4)=$35.96 Autozone Pt.#088394.
Degoated
Striker1 is offline
post #4 of 6 (permalink) Old 03-16-2012, 05:23 PM
Steve
350ernie2's Avatar
sHELL hELIX 10W 40 Hiflow oil filter. Oil level is at the top of the range . Maybe thats it
Steve
VN750
KH500
Ducati 350sss
post #5 of 6 (permalink) Old 03-16-2012, 06:31 PM Thread Starter
pittdave's Avatar
my oil level is above the HI line
Pittsburgh Dave
pittdave is offline
post #6 of 6 (permalink) Old 03-17-2012, 02:26 AM
Oil level has nothing to do with shifting, if the engine runs alright. An oil level that is really to high will cause the crank throws to hit the oil in the sump, and seriously reduce power. But it would have to be a lot to full, as the sump is mostly empty at anything above idle.
The Vulcan 750 does not like to be downshifted at higher rpms. I don't start downshifting mine until I'm below 2,000 rpm, and then often blip the throttle while shifting to line up the gears properly. If you are used to an inline four, the Vulcan is a whole different animal. I had to get used to shifting my Goldwing, it also has a clunky transmission, but if you do it just right, you rarely ever get a clunk. There is no way to shift a Harley without a clunk, the transmission is designed that way. But a Harley is a large slow moving beast that should not be rushed.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
