air/fuel mix screw - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 03-13-2012, 07:22 AM Thread Starter
pittdave's Avatar
air/fuel mix screw
CAn somebody post a pic or a link that shows me this screw..i just can seem to pin it down
Pittsburgh Dave
2001 VN750...old ride
2003 VN1600.. new ride
pittdave is offline
post #2 of 16 (permalink) Old 03-13-2012, 07:33 AM
Originally Posted by pittdave View Post
Can somebody post a pic or a link that shows me this screw..i just can seem to pin it down
Here ya go....you may need to remove the plug first...be careful.
VoIPDoc is offline
post #3 of 16 (permalink) Old 03-13-2012, 01:13 PM Thread Starter
pittdave's Avatar
found 'em.. and the caps are off so access is no issue.. what's the direction for the mix?? which way leans and richens the mix
Pittsburgh Dave
pittdave is offline
post #4 of 16 (permalink) Old 03-13-2012, 01:27 PM
I am not sure what your set up is, but turn them in all the way to bottom the screw out, and then turn them out about 2 1/2 turns generally works for starting point.
turning them out will make it more "rich".
kc2dgq is online now
post #5 of 16 (permalink) Old 03-13-2012, 01:50 PM Thread Starter
pittdave's Avatar
ok.. i'm also trying to remember if youre getting the blue-ing of the pipes just after the exhaust manifold.. is it too lean or oo rich
Pittsburgh Dave
pittdave is offline
post #6 of 16 (permalink) Old 03-13-2012, 01:53 PM
Too lean is the primary cause of bluing.
CW-4 is offline
post #7 of 16 (permalink) Old 03-13-2012, 06:49 PM
Bluing right near manifold to lean 4/5in down rich
Swagman is offline
post #8 of 16 (permalink) Old 03-13-2012, 07:30 PM Thread Starter
pittdave's Avatar
I backed out the screws about a half turn each. I am noticing a different sound.. It seems more if a mechanical sound..i have done the grambo as well and it sounds like a chain sound or a valve tap..the bike runs great..just dont know what the 'normal' sound should be
Pittsburgh Dave
pittdave is offline
post #9 of 16 (permalink) Old 04-02-2012, 10:37 PM
kctrigger's Avatar
are the caps too the screw taken out by an allen wrench cause i stripped one trying to get it out, now i don't know what i should do cause it won't budge
03 Vulcan 750 Bobber
ADDED -
Straight Slash-Cut Pipes
ISO Gribs
Heat Shields
Grill
Arrow Chrome Turn Signals on back
Harley Signals on front
Side Mount License Plate
Bobber Headlight
Mini Speedo
Solo Seat
VN 1500 Front End
Switched out Ignition and Relocated
Ear Shave
kctrigger is offline
post #10 of 16 (permalink) Old 04-02-2012, 11:06 PM
JM2001's Avatar
NO, the air/fuel screw has a recessed metal cap over it. You can drill a very small hole in it and pick it out with a sharp awl. The allen head screw is the carb drain screw.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
