Tachometer not working - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 03-12-2012, 07:11 AM Thread Starter
Steve
350ernie2's Avatar
I just purchased a 1986 750a with 31000 kms on the clock. Really nice machine with heaps of expensive stuff. Really good value and super comfortable .
I have just read he newbie stuff,...I have changed all the fluids, but now have two more jobs to do.
One minor issue with my bike is the tachometer is not working. It runs real nice, revs out through all the gears, (it has harley fatboy pipes put on my the orginal owner, maybe a bit rich ? ) I pulled apart the headlight shell, and tacho and checked all the conectors, They look fine. Before I buy a new tachometer , is there anything else I should try ?
Steve
VN750
KH500
Ducati 350sss
350ernie2 is offline
post #2 of 10 (permalink) Old 03-12-2012, 08:07 AM
MaDeInSin's Avatar
Welcome to the forum brother!
I just wanted to give you a link of a fellow member selling the tach and speedo for a pretty good price if your interested....
https://www.vn750.com/forum/showthread.php?t=20815
Others will most likely chime in on things to check with your existing tach.
Have a good one
Accomplishments;
Changed Final Drive Fluid
Iridium Plugs
NGK Spark Plug Wires
Bridgestone Spitfire Tires
Maintenance Free Battery
Lubed the Spline
Shaved and Coastered
Under Tank Air Filter
Re-Jetted
Vn900 Seat Mod w/ Honda 1100 Backrest
Rebuilt Petcock
Custom Mirrors
Custom SaddleBags
LED Taillight
Heads Up Voltage Monitor
Upcoming: Change front fork Seals & Oil, install highway pegs & floorboards
MaDeInSin is offline
post #3 of 10 (permalink) Old 03-12-2012, 11:32 AM
The tacho runs of the front coil check your wiring connects in there under the left side plastic headstock cover in front of the tank
Swagman is offline
post #4 of 10 (permalink) Old 03-12-2012, 08:14 PM
If the connections are all ok, then you will have to replace the tach. If you can find a good used one for a decent price, I'd go for it. New ones are ridiculously expensive. Are the tach light and the temp gauge working?
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #5 of 10 (permalink) Old 03-12-2012, 09:06 PM Thread Starter
Steve
350ernie2's Avatar
Yep light and Temp gauge bother are working.
Steve
VN750
KH500
Ducati 350sss
post #6 of 10 (permalink) Old 03-12-2012, 09:21 PM
romeobravo172
romeobravo172's Avatar
Got one, only you are not just around the corner! LOL-- How hard are parts to get there?
romeobravo172 is offline
post #7 of 10 (permalink) Old 03-13-2012, 07:13 AM Thread Starter
Steve
350ernie2's Avatar
I would have to ring around, and still pay postage. If you are willing to sell yours and post to Australia I am willing to buy it. It looks in good condition. I check the wiring to the coil and it look ok. So its the tacho that nees replacing.
Steve
VN750
KH500
Ducati 350sss
post #8 of 10 (permalink) Old 03-13-2012, 11:54 AM
Before you buy another one check out and clean all electrical connections, my rev counter/tacho was bouncing all over the place after cleaning and greasing all contacts on bike it settled down to normal, the electrics do odd things on these bikes
Swagman is offline
post #9 of 10 (permalink) Old 03-18-2012, 05:24 AM Thread Starter
Steve
350ernie2's Avatar
Any idea where the wires go near the front coil. Its pretty tight in there.
Steve
VN750
KH500
Ducati 350sss
post #10 of 10 (permalink) Old 03-18-2012, 07:16 AM
Have you removed the plastic head covers, once they are off you can remove the coil from the frame and give all the wires a clean up.
Swagman is offline
