leaking carbs and only have first gear!!!!!!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 03-09-2012, 10:14 PM Thread Starter
Hey everybody i have a 1995 vulcan n im leakin gas outa my carbs.. i havent had it runnin yet bt i put new pickup coils on n now have spark. somebody who had it b4 me did an earshave and honestly i dont know if the hoses are even hooked up right.. i have two coming from the center of the carbs that branch off to a t.. n two comin from the bottom of each carb that were hook iup to the petcock. also a little one going from there to the left side of the carb.. it also feels like it has no gears except for first... please help
katiebobber0608 is offline
post #2 of 3 (permalink) Old 03-09-2012, 10:51 PM
Hey kattiebobber, I haven`t done an earshave or really got my hands dirty working on my bike yet, but maybe some of these links will help you identify the hoses etc.
First link is Phil`s earshave:
http://06vn750.blogspot.com/
The two hoses coming from the center of the carb to a "T" are the float bowl vent hoses.
This diagram shows the vent hoses on the stock system plugged into the right ear, without an earshave.
https://www.vn750.com/photopost/showp...o=1757&cat=503
After an earshave either put a breather filter on the end of that vent hose, or tie it up out the wind flow, or the wind will cause erratic behhavior.
Two hoses going to the outside nipples on the petcock are the fuel lines.
The single hose coming from the left side carb vacuum port to the center nipple on the petcock is the vacuum source that turns the petcock on and allows fuel to flow.
The vacuum port on the right side carb should be plugged off after an earshave.
post #3 of 3 (permalink) Old 03-09-2012, 11:25 PM Thread Starter
Thanks man that told me everything i need to know... this sites pretty awsome i appricate it...
