marbles..where?? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-08-2012, 04:39 PM Thread Starter
pittdave's Avatar
marbles..where??
I am want to marble my '01 and am having trouble finding marbles and/or steel bearings to finish the job. I know the hose is 5/8th but the two marbles I have are smaller than that. Do the marbles need to be the 5/8 or smaller to fit inside the hose.
So where can I pick up what I need.. I've struck out at Wal-Mart, Lowe's, Dollar Tree, Auto Zone, O'Reillys..running out of options
pittdave is offline
post #2 of 7 (permalink) Old 03-08-2012, 04:56 PM
This is not for a long term fix but this will atleast alow you to finnish tweeking till you find your perminant plug.
AA batteries fit perfectly in the hose.
post #3 of 7 (permalink) Old 03-08-2012, 05:04 PM Thread Starter
pittdave's Avatar
ok.. if AAs will fit then my marbles are fine. i matched them up and they are the same size
pittdave is offline
post #4 of 7 (permalink) Old 03-08-2012, 05:21 PM
JM2001's Avatar
The easiest way, and I think better, is to buy two 1/2 " copper tubing end caps ( Home Depot .49 cents). Pull the hose, put the end caps over the tube coming out of the cylinder ( fit perfect ) and slide the hose back on over the end caps. Can't tell it's there. 5 minute job.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #5 of 7 (permalink) Old 03-08-2012, 06:48 PM
I went that route and eventually used coasters and removed the air injection system completely.
When I did the marble thing, I used glass marbles from my kids (toys) marble set.
post #6 of 7 (permalink) Old 03-08-2012, 08:02 PM
Crap, I WAS in 5th gear.
If you still hear a little pop-pop, then your marbles are too small, or you need to back out your idle screw(s) a little.
Kelly2001 is offline
post #7 of 7 (permalink) Old 03-08-2012, 09:48 PM
^^^ True ^^^
VoIPDoc is offline
