grambo and marble help for a newbie - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 03-06-2012, 05:42 PM Thread Starter
pittdave's Avatar
Hi all,
In reading these boards, i've heard of the marble trick(for popping) and the grambo trick( for engine tick).
They both seem to be easy fixes but I cant seem to find the thread which shows it all off for a newbie.
I need help
Thanks,
PD
pittdave is offline
post #2 of 6 (permalink) Old 03-06-2012, 07:16 PM
At the top of this screen, next to the bike, is a small search window.
Enter "grambo" and press <Enter>
Enter "marble" and press <Enter>
You're right, both are extremely easy to do.
VoIPDoc is offline
post #3 of 6 (permalink) Old 03-06-2012, 08:20 PM
Patriot Guard Rider
The DEUCE's Avatar
Marbeling:
https://www.vn750.com/forum/showthread.php?t=1083
Grambo Trick:
https://www.vn750.com/forum/showthread.php?t=1076
VN750 #9300 & VROC #33453
The DEUCE is offline
post #4 of 6 (permalink) Old 03-06-2012, 08:41 PM
Concert connoisseur
wib714's Avatar
theres a link in my signature that tells you how to conver your acct to a mcct. but also in there it tells you with the engine running to take the cap screw off the front cylinder acct, there is a small flat head screw inside it, if you see it jumping around when you hear the tick that is your culprit. to grambo it, shut the engine off, turn the screw clockwise a full turn and pull the screwdriver out and let it snap back, that might cure the problem for awhile, if not you might consider the homemade conversion for 10 bucks or less a cylinder like many of us have or purchase machined mccts from toc manufacturing for 50 bucks a peice! good luck
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #5 of 6 (permalink) Old 03-06-2012, 10:40 PM
First, the marble thing does work, but you will be a lot better off just getting rid of the entire air injection system, and capping off the connections at the head, either with coasters, which look nicer, or like I did, with rubber plugs. Your bike will not only run better, but you will get rid of a WHOLE BUNCH of useless junk that clutters up the bike. It made me feel real good to throw mine in the trash can.
The "Grambo trick" is more of a diagnostic tool than a fix. If doing it quietens your engine down noticeably, then you have worn out cam chain tensioners. The noise will come back. A variation on this is to actually turn the screw counterclockwise, which advances the plunger and stops the noise. But just like the Grambo trick, it will come back. I highly recommend the TOC manual tensioners. I have been using them for over 40,000 miles, and their quality is like night and day over the cheesy oem tensioners.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #6 of 6 (permalink) Old 03-07-2012, 01:25 AM
OldHipWesTex's Avatar
Send a message via Yahoo to OldHipWesTex
"Grambo trick" works for me.I just repeat it every couple of months. Just because i can
Vulcan #1 1993 - 28K
Vulcan #2 1999 - 26k
It All Comes Down To 3 Things:
#1 Fuel
#2 Spark
#3 Mechanical
Any One Fails - Then It Dont Run
____________________________________
ANTICIPATED MODS:
Build Fiberglass Fenders F/R
Mold & Cast New Turn Signals Lights
OldHipWesTex is offline
