no spark to rear cylinder... please help!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-25-2012, 08:24 PM Thread Starter
Unhappy no spark to rear cylinder... please help!!!
Hey everybody.. im knew to this site.. i have a 1995 vn 750 i bought it not running . it has no spark to the rear cylinder and ive already changed the rear ignition coil. still no fire... any sugestions?
katiebobber0608 is offline
post #2 of 9 (permalink) Old 02-25-2012, 09:29 PM
Check the resistance of the coil with an ohm meter.
Resistance in the primary, low voltage circuit, should be from 1.8-2.2 ohms.
Resistance in the secondary circuit between the two spark plug connections and through the coil should be from 19k-29k ohms.
If you get no reading you have a break in the circuit.
To determine whether the break is in a plug wire or the coil, unscrew the caps holding the plug wires and remove the wires from the coil.
Test each plug wire and the coil separately.
Plug wire should be around 5-7k ohms per foot of length.
The coil should still read between 10-20k ohms.
Let us know what results you get.
post #3 of 9 (permalink) Old 02-26-2012, 05:34 AM
As Gordon says plus have you tried different sparkplugs as the plug could be bad, and Welcome to the forum I'm sure you will find a lot of assistance here.
Swagman is offline
post #4 of 9 (permalink) Old 02-26-2012, 11:02 AM
I had the same problem with my '92, turns out that the pick up coil (located behind the stator cover) had a bad wire.. spliced the said wire and fixed the problem.
post #5 of 9 (permalink) Old 02-26-2012, 11:17 AM
Check the connection to the pick up coil wires that slim mentioned. It is behind the engine, in front of the battery.
post #6 of 9 (permalink) Old 02-26-2012, 12:20 PM
Send a message via Yahoo to yugten
is the pickup coil same as the pulsing coil (59026 59026-1062 COIL-PULSING) as described in the manual?
yugten is offline
post #7 of 9 (permalink) Old 02-27-2012, 02:41 AM
yup that is the same thing.
post #8 of 9 (permalink) Old 03-09-2012, 07:59 PM Thread Starter
Hey everybody im sorry i havent been on here for awhile just workin on this bikany help?e. anyhow i removed the stator cover n there it was one of the wires had broke off flush with the pulse coil. i got a new set and put em on i now have spark.. bt i have another problem now.. gas is leaking outa my carbs the guy who had it b4 me i guess did an earshave.. n honestly i dont no if the hoses are connected rite. i have two hose comin from the middle of the carbs n branch off to at.. i have two hoses that come off the bottom of each carb n they went into the petcock n one little one from there to the left carb. Dont know exactly where they go... also it feels like i have only one gear on the shifter????
post #9 of 9 (permalink) Old 03-09-2012, 11:31 PM
Answered in another thread:
https://www.vn750.com/forum/showthrea...399#post200399
