Center Stand spring installation - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-25-2010, 10:45 AM Thread Starter
I removed my center stand to repair and paint it from previous owner damage and wanted to install a new spring as well. I cant get the spring installed. Is there a procedure, trick or special tool needed to get this spring re-installed?
Memphis Shades sport shield
Saddleman Explorer seat
Kurykan ISO grips
Garmin GPS ram mount
Knifemaker floorboards
Auburn Leather Frontier saddlebags
Fire and Steel saddlebag brackets
OEM turn signal relocation kit
Enkei chrome valve cores and caps
Progressive front springs
Progressive 412 rear shocks
Signal Dynamics voltage LED
Metzeler ME880 110/90H-19 front
Metzeler ME880 170/80HB-15 rear
K&N air filters
RHoschett is offline
post #2 of 9 (permalink) Old 03-25-2010, 03:12 PM
You can use a large screwdriver to pry it on, but that will scratch some paint. If you have a means of stretching the spring while it is off the bike, you can insert washers, pennies, or dimes between the coils to hold them apart, install the spring, and then use needle nose pliers to pull out whatever you put between the coils. I have used this method several times, and it has always worked. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 9 (permalink) Old 03-25-2010, 05:46 PM
Concert connoisseur
wib714's Avatar
I think I used the vise grip on the spring and a heavy screwdriver to get some leverage but if you try this be sure to get the vise grips good and tight and maybe wear some gloves cause if it slips off, well you can imagine, I do it this way on my riding mower too.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #4 of 9 (permalink) Old 03-25-2010, 06:48 PM
do you have brake spring pliers or know any one who does they are great for almost any spring installation.
post #5 of 9 (permalink) Old 03-25-2010, 07:20 PM
Concert connoisseur
wib714's Avatar
awwww, but that would take the fun and danger out of it! (wish I had a pair)
42,000 miles
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
wib714 is offline
post #6 of 9 (permalink) Old 03-25-2010, 07:28 PM
It's all fun and games till some one get's hurt,Then it's hilarious!!!!! (This is a joke people and said in sarcasm so don't send me hate mail) I wish you had a pair too wib !!!LOL
post #7 of 9 (permalink) Old 03-25-2010, 07:38 PM Thread Starter
Jerry,
I had seen some other posts about pennies or washers and that ultimately did the trick..had to use 22 cents to be exact and still had to use the channel lock pliers to squeeze that last bit to get the spring end on the center stand post...Thanks for the help!
Kurykan ISO grips
K&N air filters
post #8 of 9 (permalink) Old 03-25-2010, 07:49 PM
Ron
Ron's Avatar
As close as your nearest Sears store.
http://www.sears.com/shc/s/search_10...e+tools&vName=
Ron
Ron is offline
post #9 of 9 (permalink) Old 03-27-2010, 03:12 AM
I have every brake tool made for cars and light trucks. I do not own any air (spring) brake tools, but use them at work. But on bikes, I prefer to do things in such a way that nothing gets damaged. Who cares if you scatch a dump truck? But I don't want to scratch my bike. And yes, both my car and truck have drum front brakes, neither one power assist, so I have the tools to work on them, including one of those really cool little gadgets to repack wheel bearings with a grease gun, and a MityVac to bleed the brakes with.
BTW RHoschet, glad you got it on. Jerry.
1979 Vespa P200E
