balancing dampers. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-16-2010, 08:02 PM Thread Starter
balancing dampers.
how ya gettin on?i took off the stator cover and had a look .everything looks ok.where are the dampers and what do they look like?
bacon is offline
post #2 of 3 (permalink) Old 02-16-2010, 10:02 PM
skalding's Avatar
Bacon,
Please stick to posting about one issue in one thread. It makes it easier to follow your issue and help you. I'm certainly not going to jump around 4 different threads to compile information about what's going on with your bike.
Every time you put in a new post the entire thread gets "bumped" to the top of the list again. Don't worry - people will see your new post.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #3 of 3 (permalink) Old 02-16-2010, 10:44 PM
Posting this along with your oil question in the Engine/Transmission section would also generate more replies. The Dampers are located behind the stator... HERE is a thread on balancer replacement. there are quite a few more threads with pics... if you have a digital camera you could take pics of your balancers and we should be able to help you determine if the balancers are kaput.
