86 vulcan 750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-31-2010, 04:15 PM Thread Starter
86 vulcan 750
hey everyone. im in portugal cove newfoundland . anyway i took off the carbs and took out the jets and the main was full of old crap thanks for the help.but looked into the rear cylinder intake theres a lot of carbon in there whats the best way to get it out? bacon
bacon is offline
post #2 of 7 (permalink) Old 01-31-2010, 05:12 PM
The Professor
lance328's Avatar
Use a couple ounces of Seafoam in every tank of fuel, it will clean out the carbon.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 7 (permalink) Old 01-31-2010, 06:59 PM
Did you happen to look into the front cylinder intake, and if so, did the rear cylinder have more buildup? Keep in mind that on an older bike, there is going to be some buildup, especially if it was used for a lot of stop and go riding, and started often with the choke on. Also, things can look worse than they are. It is normal for it to be black in there. Remove the plugs, and with a tiny little flashlight, look into the cylinders and see what the top of the pistons look like.
Aside from that, how does the bike run? If it runs good, then I agree, just start putting Seafoam in the gas, that will help clean it out. If it runs poorly, or is pinging (detonation), there may be so much carbon in the combustion chamber that it has raised the effective compression ratio. If that is the case, you may need to actually remove the heads and clean it up.
I would suggest hotter plugs, but if you decide to do that, you are on your own. I don't know what your riding conditions are, and plugs that are too hot tend to burn holes in pistons. Jerry.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #4 of 7 (permalink) Old 02-01-2010, 04:58 PM
Welcome to the Vulcan madness, bacon. It`s always good to have another Canuck on board. WE may be in the same county, but are probably farther apart than either one of us is from most of the Yanks/or Rebs on the board here. I think Ft. McMurray in northern Alberta, has the biggest population of Newfies anywhere outside of Newfoundland.
I hope a couple of ounces of Seafoam in every tank of gas is all you need to clean the carbon out after you get the carbs back on.
See the link below, and pay particular attention to the rear spline lube, a MF-AGM battery and NGK Iridium spark plugs. Enjoy the ride.
post #5 of 7 (permalink) Old 03-06-2010, 07:07 AM
Hello, I've been to Portugal Cove, nice place.
cdaddy is offline
post #6 of 7 (permalink) Old 03-07-2010, 10:09 PM
Hello,
I have read in here in a number of forums. Where can you buy this Seafoam? At the motorcycle shop? So it's pretty good stuff to clean out the carbon build up?
I just took apart my Rebel 250 03' with only 3900 miles on it. I did a compression check on it and one cyl. was low. So I did a valve adj. on it. It still came up low...To make sure ,my friend also did it to make sure. Still low. I don't normally like to let friends borrow any of my motorcycles but did for 2000 miles worth. I got it back and noticed the oil a bit low. So I figured the rings went bad. I know only 1 cyl. was low and why not both. I also thought maybe carbon build up on valves. Get to the point already... ok.
Tore top end apart and one cyl. had carbon build up so valve wasn't closing all the way. Was wondering if the seafoam would have cleaned up enough before I decided to tear it apart? Thanks now.
crf450rman is offline
post #7 of 7 (permalink) Old 03-08-2010, 09:54 AM
flitecontrol's Avatar
SeaFoam is available at many auto parts stores and the local Walmart. This should answer your questions about what it will do. http://www.seafoamsales.com/
Many here have used it and are true believers.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
