Old gasket clean-up - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 12-20-2009, 12:37 PM Thread Starter
Old gasket clean-up
Whatís the best way to clean off old gasket residue?
My í86 VN750 is getting her 3rd stator.
This is the first one that Iíve installed.
The previous owner installed an after market stator.
It lasted a month and was replaced under warrenty.
A year later I buy the bike and the stator goes out in three days.
Given this history and the info Iíve gathered from this very helpful site,
Iím a little gun shy about the current crop of new stators available.
On Ebay I found a case with stator and pick-ups installed.
The stator appears to be original and measures OK with an ohm meter.
Although this Ebay case is alittle rough on the outside, Iím leaning toward using it rather than trying to move the stator from one case to another.
Opinions and help with the gasket cleanup please.
Thanks
Mo
moloprintz is offline
post #2 of 7 (permalink) Old 12-20-2009, 01:25 PM
Simple Solutions
seebeeare's Avatar
i recomend getting the stator rewound by tpe-usa.com though it will take them 2 to 3 weeks its a great stator ...
to clean gasket material i use a scraper then a brass brush on my drill ... brass being softer then aluminum it wont gouge the cases
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 7 (permalink) Old 12-20-2009, 02:37 PM
flitecontrol's Avatar
There is a spray material that is excellent for removing old gaskets. But I can't remember the name of it at the moment. Check with an auto parts store; they should have it.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #4 of 7 (permalink) Old 12-20-2009, 04:30 PM
Send a message via Yahoo to luigit
i have used WD-40 and/or PB blaster. let it soak in, then a scaper VERY GENTLY!!. Followed up with some 800 grit sandpaper i had. turned out great for me!
luigit is offline
post #5 of 7 (permalink) Old 12-20-2009, 06:15 PM
i use a wire wheel on a drill, or a "Gasket Scraper" (looks like a putty knife, but a little thicker and has a sharper blade), or for the really tough gaskets, I use a digrander with a "Flapper Wheel".
post #6 of 7 (permalink) Old 12-20-2009, 10:25 PM
The Professor
lance328's Avatar
Gasket scraper and Roloc Scotch Brite on a mini angle grinder has work great for years.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 7 (permalink) Old 12-21-2009, 08:26 PM
that is what i was referring to as a "Flapper Wheel"... couldn't remember the proper name...lol
