Gibbsail from Florida checking in... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 11-03-2009, 08:32 PM Thread Starter
Gibbsail
gibbsail's Avatar
I have a 2004 vn750. My first bike, Had it since it was new. I now have 10,000 miles and had a little problem the other day.
The idle is set at 1100 and on the way home at a stop it seemed to be idling too low, i proceeded to ride home and around 65 mph ( bike at temp) i lost power until she stalled. Would not restart untill i waited about 25 mins then started and rode rest of way home.
Anyone have ideas????????
Regards,
Gibbsail
gibbsail is offline
post #2 of 18 (permalink) Old 11-03-2009, 08:52 PM
Love My Baby
rubyrick's Avatar
Regards,
Gibbsail
Several things come to mind. Might be the "phantom out of gas" syndrome. Were you at about half a tank of gas? Sometimes popping open the gas cap to let the pressure vent helps. Also, check your spark plugs and your vacuum hoses. But my first guess is the phantom out of gas syndrome, do a search on the forum.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #3 of 18 (permalink) Old 11-03-2009, 08:56 PM Thread Starter
Gibbsail
gibbsail's Avatar
Wow, that sounds strange but both times it happened i was at or below half a tank.
gibbsail is offline
post #4 of 18 (permalink) Old 11-03-2009, 09:03 PM
Love My Baby
rubyrick's Avatar
You might need to service your gas cap vent hole if it happens again. I found that when these symptoms happen, being real easy on the throttle, slowly increasing it and backing off just before I feel it's gonna stall helps me not stall. But if I do stall, popping the cap and waiting a minute helps. BUT - this hasn't happened to me in over a year now.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
X
rubyrick is offline
post #5 of 18 (permalink) Old 11-03-2009, 09:07 PM Thread Starter
Gibbsail
gibbsail's Avatar
Thanks, i looked it up on the forum and that sounds like my problem. I'm going to inspect the line for cracks and service the cap. thanks RubyRick!!
gibbsail is offline
post #6 of 18 (permalink) Old 11-03-2009, 09:31 PM
flitecontrol's Avatar
Welcome, from a former resident just up the coast; Cocoa Beach. Aren't you glad you joined us? Lots of knowledgeable folks here.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #7 of 18 (permalink) Old 11-03-2009, 09:33 PM Thread Starter
Gibbsail
gibbsail's Avatar
Yes it's great. Thanks for the welcome...
Tell me about relocating the rectifier and about the coil adjustments???
gibbsail is offline
post #8 of 18 (permalink) Old 11-03-2009, 09:40 PM
The stock R/R location is bolted to the underside of the battery box, which is right above the "goat's belly" (premuffler or whatever the correct term is), which generates a LOT of heat. The R/R produces a lot of heat on its own. Trouble is, the hotter the R/R stays, the more likely it will fail. So moving it to a cooler location prolongs its life. The usual relocation is to a bracket made to bolt onto the left rear peg bracket. Do a search for R/R relocation bracket and you should find a pic of one. I used a piece of 1/8" thick aluminum sign material from the local recycler to make mine. Two holes in the aluminum plate to bolt the R/R to and one for the peg bracket bolt. You'll probably need a longer peg bracket bolt.
"Black Beauty"
Old Blue
post #9 of 18 (permalink) Old 11-03-2009, 09:47 PM Thread Starter
Gibbsail
gibbsail's Avatar
what do you think about degoating?
gibbsail is offline
post #10 of 18 (permalink) Old 11-04-2009, 08:15 AM
Lots of folks have done it. I left mine because the R/R relocation is a lot easier and I didn't want to go to the trouble. If you know you're going to an aftermarket exhaust at some point in the future, leave it and take it off when you install the new exhaust.
"Black Beauty"
Old Blue
