1985 kawasaki vn700 a1 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 09-15-2009, 10:28 AM Thread Starter
Send a message via Yahoo to newguywithbike
hay guys i was wondering if anyone has a pdf copy of the service manual for this bike if so can anyone share a copy of it for me i would be greatfull thanks
newguywithbike is offline
post #2 of 8 (permalink) Old 09-15-2009, 10:47 AM
Search Goddess
Dianna's Avatar
Go to http://www.tocmanufacturing.com/Products.htm
scroll down until you see ..
Other Links:
Link to VN700/750 Service Manual in PDF format (WARNING 117MEG file) click here
Right click the here and do a "Save Target As.."
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
post #3 of 8 (permalink) Old 09-15-2009, 09:36 PM Thread Starter
hay guys got a prob need some info when i try and start my bike it doesnt seem to want to start but then it back fires and its loud as **** but then it will start after a few more tries is it the spark plugs let me know
post #4 of 8 (permalink) Old 09-15-2009, 09:43 PM
flitecontrol's Avatar
Could be. Have you pulled one from each cylinder to see what it looks like? Here's a chart http://www.dansmc.com/spark_plugs/sp...s_catalog.html The iridium plugs really help eliminate starting problems, assuming you don't have a carb or similar issue going on.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 8 (permalink) Old 09-16-2009, 12:45 AM
The Professor
lance328's Avatar
Replace plugs with NGK Iridium DPR7EIX-9 and replace battery with an MF AGM ETX15L.
http://cgi.ebay.com/ebaymotors/Deka-...ehicleQ5fParts
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 8 (permalink) Old 04-14-2011, 10:45 PM
Candyman
VN700A speedo
I need a speedometer for a 1985 Vulcan VN700A. Kawasaki says discontinued and no luck with over a dozen different sites. Where can I find a replacement speedometer?
TIA Candyman
Candyman is offline
post #7 of 8 (permalink) Old 04-14-2011, 11:07 PM
JM2001's Avatar
TIA Candyman
Try here
http://shop.ebay.com/?_from=R40&_trk...All-Categories
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #8 of 8 (permalink) Old 04-14-2011, 11:08 PM
Harley's Avatar
Hey there, I have had pretty good luck with ebay and alot of the kn7** parts are interchangeable with each other. should be able to pick one up pretty reasonable. Safe Journey !
Harley is offline
