Newbie questions - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-28-2009, 02:09 PM Thread Starter
dagmar's Avatar
Newbie questions
My father and I have been doing some work including fabricating a new seat, Backrest and Rack. The next step for my bike will be to finish the exhaust and the ear shaving. I was wondering if there is a difference If I install an aftermarket case or just installing a set of K&N filters with no casing at all.
The other issue that just started is that when ever I use my front break harder then normal I smell burning rubber. Does anyone know what the cause of that would be?
Koal
dagmar is offline
post #2 of 6 (permalink) Old 07-28-2009, 05:17 PM
Calif Rider
weh44att's Avatar
The brakes are not rubber and you would not get that type of smell because of the brakes.
Check the front tire and wheel is it loose somehow, I mean is it rubbing against the fender or forks when you hit the brake hard. That would be about the only thing that would give you a rubber smell. I would say the K+N filters would be easier to do. Hope this helps.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 6 (permalink) Old 07-28-2009, 05:57 PM
Welcome to the Vulcan Madness dagmar. Where are you from? Your question about the k&N filters is confusing to me. I have no experience with doing an earshave, but there are two types of K&N filters for the vn750. There are some foam filters that simply replace the OEM Kawi ones inside the airbox. Then there are the filter "pods" that mount directly to the carbs with no airbox. Does that answer your question at all?
As far as the burning rubber smell goes, the next time you smell it, stop and get your nose down close to the brake pads and disc to see if you can discover the source.
Keep the rubber on the road, and the shiny side up.
post #4 of 6 (permalink) Old 07-29-2009, 09:16 AM Thread Starter
dagmar's Avatar
I am from MN. I was wondering if there is a performance difference if I built a case for the air filters of if I just left them open to the world. I was thinking of building a small box for them that will act like a ram air system so that there is no heat from the engine getting to them. though it won't be nice looking I could build it for function. But nothing else on my bike that I have fabricated is all that nice looking.
dagmar is offline
post #5 of 6 (permalink) Old 07-29-2009, 04:03 PM
Gemguy's Avatar
performance suggests that there is some speed involved. when you are moving the air that goes to the filters is coming in from the front ahead of the engine and seems that it should not be heated up. you may want to look up on this forum the posts about "ear shaves" which deals with removing the air filter boxes altogether.
good luck
~VROC~ # 389
Gemguy is offline
post #6 of 6 (permalink) Old 07-30-2009, 08:35 AM
Making a custom Ram Air type box, or removing the box all together, will require rejetting the carbs.
As I've said many times here, I ran once with just the chrome covers off the ears. Bike would run like crap over 4k RPM's.
