Newbie with a problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-19-2009, 07:38 AM Thread Starter
Richmond, VA
Purchased 95 VN750 w/19.5k miles ($550). 3k miles later I'm told I have a cam gear or cam chain noise. Recommended that I ride the bike till it dies then scrap it. Don't have know how or tools to repair myself. Your recommendations would be appreciated.
Thanks from Richmond, VA.
Rodd is offline
post #2 of 7 (permalink) Old 07-19-2009, 07:43 AM
750Doug's Avatar
Do a forum search, and look in the Vulcan Verses for info on ACCT and/or MCCT.
(auto cam chain tensioner / manual cam chain tensioner)
It's a common problem on these bike for the ACCT on the front cylinder to lose it's ability to keep the chain snug and quiet. And the fixes at this point are relatively easy and affordable, and many, many of us have done them already.
The "fixes" don't require engine teardown or removal, and we have lots of pics around here to go with the info.
You don't need to ride it til it breaks and then scrap it.
750Doug is offline
post #3 of 7 (permalink) Old 07-19-2009, 07:50 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
X2 - Sounds like you'll be riding it for many years to come before it hits the scrap heap. These bikes are like the old Checker Marathons, they never die. If you don't want to fix your ACCT, which is very easy, you can buy a new or used one on Ebay for about $80. Do what Doug said, check the Verses.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #4 of 7 (permalink) Old 07-19-2009, 10:41 AM Thread Starter
Richmond, VA
It ususally happens when the bike is cold. Should I stop riding it until I fix the ACCT?
Rodd is offline
post #5 of 7 (permalink) Old 07-19-2009, 04:08 PM
Love My Baby
rubyrick's Avatar
No. Do what I do and you shouldn't have a problem until it's fixed. Start the bike and use the choke very sparingly, just enough to prevent the bike from stalling, and don't ride for two minutes. Let the bike warm up just a bit without idling too high and you shouldn't hear the noise as much. Then you can ride once it's a bit warmed up.
If the rattle is still bad even with low idle, you can either grease your ACCT following THIS THREAD or replace your ACCT with an MCCT from THIS SITE. Follow the Vulcan Verses on how to do this and you should be fine.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 7 (permalink) Old 07-19-2009, 07:09 PM
Concert connoisseur
wib714's Avatar
my 12 yo could swap out my accts if that makes you feel any better, its that easy. just dont turn the engine while they are out.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #7 of 7 (permalink) Old 07-19-2009, 07:59 PM
The Professor
lance328's Avatar
You can replace the ACCT springs and they may fix the problem or replace with MCCT's and it will fix the problem. Link below
http://www.tocmanufacturing.com/Manu...nTensioner.htm
http://www.tocmanufacturing.com/ACCT.htm
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
