1994 sound ok - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 07-17-2009, 08:17 PM Thread Starter
1994 sound ok
I've decided I want a Vulcan and found a '94 here in the Boston area. The bike looks in fairly good shape, but I have a couple of questions.
The tires look original (11,000 miles on the bike). A little cracking on them. I'm going to shoot for new rubber. How much rust is ok at this point? There really is only a little here and there. And last, the seat has a big rip on the bottom fold.
The KBB value is about $2400. The guy is asking $2000. Due to the tires, I'm looking to knock it down several hundred. Since I don't think there has been any other maintenance done on the bike, is $1,600 a fair price?
I don't want to screw either one of us. Thanks.
dudew1 is offline
post #2 of 15 (permalink) Old 07-17-2009, 08:29 PM
The Reanimater
jthill524's Avatar
Location: A Little Town Along I-5 in Northern California
The Bike is only worth whatever your willing to pay for it.
It just depends if He's willing to take for it what your willing to pay.
JaY
"Veronica"
2002 VN750 Vulcan
Rebuilt Engine
ACCTs lubed w/TOC Springs
Pick-up Coils Gapped at .018"
Splines Lubed
Deka MF AGM EXT15L Battery
NGK Iridium IX Spark Plugs
R/R Relocation Fix
New Rear Rack
Stock Seat Repadded
Ext-BackRest
jthill524 is offline
post #3 of 15 (permalink) Old 07-17-2009, 09:04 PM
Calif Rider
weh44att's Avatar
You need to really check the bike out. Make sure everything works, and starts okay. If not do you have somebody that can check it out for you. Take it for a good ride. After buying the bike make sure you do the used bike check that is on the sight. There are a lot of things to check.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 15 (permalink) Old 07-17-2009, 09:20 PM
93VN750's Avatar
If you have access to a voltmeter, take the seat off, start the bike, measure the voltage at the battery terminals. When you rev it up, voltage should climb from 12 - 13Vdc, up to at least 14Vdc. If it does not, it's charging system problems. On a bike that old, if it hasn't had a stator and r/r put in, it probably will need them. Probably close to $ 700 for a shop to do, almost $ 300 in parts for you to do.
I'd start here, if you get past this, then lets talk.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 15 (permalink) Old 07-17-2009, 09:31 PM
Drive less, ride more...
theauhawk's Avatar
The VN750 is a great bike, and the last of its kind...you just need to find one that you can trust as you ride it. The bike was built for 20+ years, so spare parts will generally be available for a long, long time. Another major perk with this bike--lots and lots of support and camaraderie on this forum.....
On a VN750 that old, you really, really need to test the bike's charging system b4 you get serious with it.
To do this, you'll need a good multimeter. The rest you can do via the "used bike check" found on this forum's "Vulcan Verses" at....
https://www.vn750.com/forum/showthread.php?t=1191
Also, look underneath the bike's battery tray, for signs that battery acid has attacked the frame underneath--once this has started, there's no stopping it. Walk away from the bike if you see signs of this problem.
If the charging system shows problems, repairing that can be a least several hundred dollars. Your best bet then is probably to just find another VN750. This is not hard, as there are a lot of them out there....
If you can, it's not a bad idea to look at the inside of the fuel tank (using a dentist's mirror, and a flashlight), for signs that the walls have rust. Its' a major hassle to fix a rusting tank.
New tires are $200-$400 down here, depending on what brand/model you get, and who replaces them for you. He may already has figured that in his asking price. Sounds like you'll need a new seat, too.
Lots of other good info on this website/forum for inspecting a used VN750....use the "search" function in the menus above, to find more info as you need it.
Good luck--and welcome to the forum...........
'05 VN750
theauhawk is offline
post #6 of 15 (permalink) Old 07-17-2009, 09:45 PM
Is it the same color as mine? I paid $2,100 for mine with about the same milage last January 08 (now at 16,000+ miles). Mine had minor rust on the gagues and was missing both swing arm caps, that was all. Sounds like you have a little room to work on the price. Just make sure it starts well and runs good like everyone suggested.
post #7 of 15 (permalink) Old 07-18-2009, 10:37 AM Thread Starter
Wow, I just wanted to ride
I found another bike. A '99 for a few hundred more. After reading your comments I'll look at that one before deciding.
I assume for the '99, I need to do all the same checks. (are the electrical systems really that bad?!)
Thanks for the help!! To bad you can't come with me to look at the bikes. I'd buy you a beer
dudew1 is offline
post #8 of 15 (permalink) Old 07-18-2009, 10:46 AM
Concert connoisseur
wib714's Avatar
yes and no. depends on the upkeep, oil changes etc and the amount of acces you add, not much room for elec access unless you led taillight mods etc. they really are a great bike. stators do fail but so do altenators on your car, just a bit more difficult to replace on these bikes.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #9 of 15 (permalink) Old 07-18-2009, 10:48 AM
The Professor
lance328's Avatar
Is that the one in Medway, listed as a 4 cylinder for $2500.00?
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #10 of 15 (permalink) Old 07-18-2009, 12:57 PM Thread Starter
uh, yeah, why? you see if first?
1999 4 CYLINDER BLUE & BLACK - VERY RELIABLE BIKE WITH CUSTOM SEATS , AFTER MARKET SADDLE BAGS & WINDSHIELD.
dudew1 is offline
Tags
1994 buy first bike
