Problems! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 07-15-2009, 08:11 PM Thread Starter
Problems!
I have a 91 750. Today my bike wouldn't start. It wont make any sound at all no crank or anything. So I got to thinking about the safeties with the headlights and yanked it out it is blown. Parts shops are closed now! %#@*. If the headlight is out will this prevent the bike from starting? I thought I read somewhere bikes newer than 90 have to have the headlights on at all times to run. True? Also on the highway around 75 or 80 it chugs or surges I can only hear exhaust coming out if one side the other side is on and off and it lurches and won't really accelerate. What is the deal with that? Help!!!
ajfletcher07 is offline
post #2 of 16 (permalink) Old 07-15-2009, 08:54 PM
The Professor
lance328's Avatar
Our headlights do not come on until you start the engine.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 16 (permalink) Old 07-15-2009, 09:31 PM Thread Starter
Any ideas on why it wouldn't start out off the blue? No warning or problems. I'm stumped.
post #4 of 16 (permalink) Old 07-15-2009, 09:32 PM Thread Starter
Electrical short?
post #5 of 16 (permalink) Old 07-15-2009, 09:45 PM
The Professor
lance328's Avatar
Make sure it is in neutral, sometimes the start button needs to be cleaned. Remove and clean ALL battery contacts, frame grounds, engine grounds, starter connections, and solenoid leads and connector. Also check the back of the fuse box for acid damage.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 16 (permalink) Old 07-15-2009, 09:49 PM
Sometimes although rare a batt will go bad just like that. (snapping fingers)
post #7 of 16 (permalink) Old 07-15-2009, 11:25 PM
I went thru this lately and the starter brushes were hanging up in their rigging,I know the manual tells you not to do this but if you hear the starter relay click and the starter does not turn ,Tap the end of the starter verylightlya quarter inch ratchet is big enough or a rubber mallet if you don't swing it too hard if the relay doesn't click when you hit the starer button don,t do this as your problem is elsewhere,Have you checked the fuses under the side cover yet?
post #8 of 16 (permalink) Old 07-15-2009, 11:25 PM
rider
global_recon's Avatar
do you get any dash lights when you turn the key on? if not, it's definitely an electrical issue. check the obvious stuff first... battery, battery leads and fuses. i have a 91 as well and had two similar issues. i had a bad ignition switch which would occasionally act like i'd turned the key to the off position. when that happens, you'll lose all lights and the bike will basically die until electrical contact is restored. in my case, if i jiggled the key when this happened while i was riding, the bike would roar back to life. just an idea. i also had a rotted grounding wire which needed to be replaced.
as far as the surging goes... when that happens, notice if you're losing lights. again... points to an electrical issue. if you're lights are fine, it's something probably unrelated. .. maybe phantom out of gas syndrome (search this site for more info).
paul
1991 vn750: 'for great justice'
http://www.globalrecon.org
follow my rides on twitter: http://www.twitter.com/globalrecon
global_recon is offline
post #9 of 16 (permalink) Old 07-16-2009, 02:04 PM Thread Starter
Thank all!
Lights come on. It has power. Battery has a good charge. Grounds are good. I'm starting it the same way I always do. In neutral. Arrrrrrrrrrrgggghhhhh!
post #10 of 16 (permalink) Old 07-16-2009, 02:05 PM Thread Starter
It makes no sound what so ever when i hit the start button totally silent
