99 750 Vulcan - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 81 (permalink) Old 05-07-2020, 06:30 PM Thread Starter
Jonathan Patterson's Avatar
It's done not the prettiest looking but it will hold oil and not leak I plan on keeping the bike and giving it to my son so as long as I am happy with it that all that counts right lol waiting on my stator rectifier and stator plate I wish the plate was cheaper 90 is expensive
Jonathan Patterson is offline
post #12 of 81 (permalink) Old 05-07-2020, 07:30 PM
99 750 Vu
If you compare similarly sold items in the moto world that are 'trick pieces', and also hard to find, around $100 doesn't seem too awfully bad.
I know there's got to be some examples, adapter plates, for engine-trans. As far as I know there's only two places to get the Tux plate, but everyone has trans adapters.
Are you saying you got your cover done today? Cool
post #13 of 81 (permalink) Old 05-07-2020, 07:34 PM Thread Starter
Yeah I got it cut from the bike and all cleaned out Saturday I should have my parts to put back together I am going to run the used oil for warm up change it and filter then I am going to put new in run it for about 30 miles and change oil and filter again
post #14 of 81 (permalink) Old 05-07-2020, 08:02 PM
Add the correct amount of Seafoam to the present oil if you want to clean out, should be 3oz but double check. I ran 200 miles but I was thinking It had a sticky valve stem.
post #15 of 81 (permalink) Old 05-07-2020, 08:07 PM
What am I thinking... We're talking about the Tuxcut. . 200 miles.. no.
Still can't edit or quote, or copy paste.. on cell.
post #16 of 81 (permalink) Old 05-07-2020, 09:48 PM Thread Starter
Yeah talking about getting the shavings out of the motor I think I did a decent job of sealing everything up but I know how damaging shavings can be probably going to come home tomorrow after work and reflush with more kerosene
post #17 of 81 (permalink) Old 05-07-2020, 10:09 PM Thread Starter
And to edit post click on the box to the right of your post top right corner of your screen will be a pencil icon click on that
post #18 of 81 (permalink) Old 05-08-2020, 12:59 AM
Thanks found and used! Thanked you in another post and called you Jason. Those two JPs we have now.
post #19 of 81 (permalink) Old 05-08-2020, 12:17 PM
Jason Pittenger's Avatar
Yes my own mod is ongoing.
https://www.vn750.com/forum/19-elect...-mod-tips.html
But if successful, I should be able to put the factory cover back on with the factory gasket.
Essentially, it involves removing 1/16" from the mounting holes to accommodate the new plate.
My machinist used 1/8" aluminum instead of 16 ga steel, so I trimmed down the mounting holes on both the main cover and the stator cover to gain 1/8".
I wanted a clean look, and I plan to mess with ignition timing later, so I didn't want to have to re-goop on a gasket every time I pull the cover.
Completed modifications:
Planned modifications:
Jason Pittenger is online now
post #20 of 81 (permalink) Old 05-09-2020, 12:27 PM Thread Starter
Thanks for the info I plan on keeping the bike for my son he is 14 and loves to ride with me he has rode many of dirt bikes so I think the 750 will be a good starter bike for him I plan on bumping up to a 1600
