light thread test - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Testing Grounds Test your signatures / avatars. This forum is wiped clean periodically
Avatars are limited to 125X125 pixels and signatures are limited to 500 characters
post #1 of 1 (permalink) Old 10-06-2009, 03:43 PM Thread Starter
Adventuregeek
Tiki Mon's Avatar
light thread test
This is a photo guide to installing the Electrical Connection turn signal conversion and running the wires through the signal stems. You can't run the wires next to the socket as instructed - it's too tight and will actually mash the insulation off the wires.
Let's start with the signal unit off the bike, and the lens removed.
Remove the screw holding the stem retainer clip and pull the clip.
Grab the socket by the little tab and pull that up to remove it.
Now you have to remove the rubber stem from the light housing. I made this easy on myself by cutting a notch in the front of the stem so the lip would push in with less effort. The clip holds the stem in the housing, so wot the heck?
Laissez les bon temps rouler!
Coastered, R&R relocation, MCCT's, Koso mirrors, Memphis Shades windshield, Mutazu GA hard bags, big monkey in the saddle. ATGATT: Olympia AST hi-viz jacket, Recon 2 (convertible) pants
Tiki Mon is offline
