How To Adjust A Motorcycle Chain - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
News and Announcements Information and news related to the website
 1Likes
  • 1 Post By OleDirtyDoc
post #1 of 5 (permalink) Old 06-27-2016, 04:51 PM Thread Starter
Sponsored Editorial Content
Walk around at any motorcycle gathering and count the bikes with limp, sagging chains. Often, the worst examples also are bone dry with rust and/or crud built up on them. Since youíre a MO reader and regularly clean/lube your chain, youíre ahead of the game. However, you still need to make sure that the chainís slack is within specifications. If you lube your chain regularly, you will probably not need to adjust it every time you return from a ride, but as a chain nears the end of its usable life, you will need to adjust the slack more and more frequently.
Although a rear stand is not required to adjust your chain, it will make the process much easier. When your chain is cold, measure the slack halfway between the sprockets by moving the chain up and down. Press down on the chain slightly to make sure it is at its lowest point. To get an accurate reading, hold a tape measure in front of the chain and look across the top of the links. Adjust your line of sight until the tops of both sides of the chain line up, which assures your eyes are perpendicular to the chain and parallel with the top of the links.
Next, move the tape measure so that one of the inch markings aligns with the top of the chain. Now, press the chain up until it is tight, and, bringing your vision up to align the top of the chain again, note the measurement. A little math will tell you if you if the slack is within your bikeís recommended specifications. Since chains donít always wear evenly, check the slack measurement in a couple of places. If you need to adjust the chain, set the chain tension to accommodate the tightest point. Also, if the chain is dramatically tighter in one place, consider replacing it.
Find Out How To Adjust A Motorcycle Chain at Motorcycle.com.
Motorcycle.com is offline
post #2 of 5 (permalink) Old 06-27-2016, 05:35 PM
Really?have you adjusted your chain on your VN750 today?if not you better get out and do it quick.
ruger likes this.
post #3 of 5 (permalink) Old 06-27-2016, 06:01 PM
Headbanger/Popes of Hell
ruger's Avatar
true, so true.
that reminds me, I need to go out to the garage and "adjust the chain" on my VN750, so it doesn't run away! I've got to make sure it's good and shackled.
ruger is online now
post #4 of 5 (permalink) Old 06-27-2016, 07:01 PM
hey now, there are 4 chains afterall...
michiganteddybear is offline
post #5 of 5 (permalink) Old 06-28-2016, 12:37 AM
I'm glad I read it.I almost put my chain on upside down and backwards.
You may not post new threads
