Which do you prefer? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 3 (permalink) Old 02-13-2018, 02:20 PM Thread Starter
ModernDayRenegade1994's Avatar
Hi guys!
So, I'm almost done with the tuxedo mod on my bike(will be posting pics prior to closing things up). Just getting everything tested out before the final installation (locking my bolts and screws down with the blue Loctite thread locker) ( stator and r/r have already been tested with my millimeter) (no interference with the new stator setup and rotor... used the duck tape method).
So my ? Which is better to use in the long run, The blue rtv gasket maker or the Black? I will be using either or on the side of the motor where the stator wires are fed through. I've decided not to notch out a portion of the side cover for my stator wires (which some do) but in lieu, I'm just going to feed the wires back through the original hole. I'm aware that I will need to put some type of Gasket making material there to prevent any type of oil leakage.
The last pic of the bike (with the RED square outlined) is where I will be using the gasket maker.
ID:	42442   Click image for larger version
ID:	42450   Click image for larger version
ID:	42458   Click image for larger version
MODERN DAY RENEGADE
ModernDayRenegade1994 is offline
post #2 of 3 (permalink) Old 02-13-2018, 06:24 PM
I usually pick up the blue, which is what I used on my clutch cover. Either should be fine.
Over the past year or two, I've seen nothing but good comments about The Right Stuff, which is what I'll try next. Don't know what color it is. Always need a new tube, it doesn't keep very well once it's opened.
A few here have mentioned using Right Stuff on the stator wire grommet.
post #3 of 3 (permalink) Old 02-13-2018, 06:49 PM Thread Starter
Thumbs up
Ok, good deal thanks!
MODERN DAY RENEGADE
