Oil Filters - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 01-28-2018, 02:42 PM Thread Starter
ubertalldude's Avatar
Oil Filters
Basic Specifications for our filters
Thread = 20x1.5 mm
Diameter = 2.69"(68mm)
Gasket O.D. = 2.475"(63mm)
Gasket I.D. = 2.173"(55mm)
Height = varies
Bypass Valve Press. = 8psi-15psi (depends on the manufacturer's listing, 8psi for Wix, 9-15psi for Fram)
Models that will work on our bikes (this list is preliminary, and I will edit and add any suggestions others have)
Oil Filter Options:
Car Filters :
Bosch 3323(taller)/D+3323(extended interval)/3300(shorter) Used to have a d+3323w/ no issues. D+3323 is billed as an extended interval filter, but is apparently of inferior construction according to a BITOG forum teardown. 3300 & 3323 rate great on BITOG
PureONE PL14610(taller) / PL-14612(shorter) according to the BITOG forums these are fantastic and nearly identical to the comprable Bosch, and seem to be less expensive. Synthetic compatible
Mobil1 M1-108(A)(short) / M1-110(A)(longer) good reports,
synthetic compatible, used the 110A on mine during the most recent problems,
may not be the issue
WIX 51365(shorter) / 51358(medium) / 51356(taller) good name, good reports of quality
Motorcycle Specific Filters (Probably won't be purchasing these, but listed since I did the research on fitment for our bikes)
Kawasaki 16097-1072 is OEM, so I would trust that just about as well as anything else
Filters to avoid:
K&N KN-204 USERS REPORT ISSUES, NOT HIGHLY RECOMMENDED
Supertech ST6607(short)/ST7317(long) USERS REPORT ISSUES, NOT HIGHLY RECOMMENDED
FRAM Anything I don't believe Fram makes one of their super-high-end filters for our bikes (the only ones which they make that are good), so stay away from the ones that do fit
ubertalldude is online now
post #2 of 7 (permalink) Old 01-28-2018, 02:49 PM
Been a while since I looked for one, but the K&N number used to be KN-303 or KN-303c (chrome). This was the one with the hex head on the end. Maybe they've changed the number or the filter design?
We needed an updated filter number list.
post #3 of 7 (permalink) Old 01-28-2018, 05:16 PM
Note: I'd personally avoid K&N filters. They have been having issues leaking where the nut attaches, even if you didn't use it to tighten. I've seen many people with oil covered rear tires due to it!
post #4 of 7 (permalink) Old 01-28-2018, 06:56 PM
mine usually leaks at the end,but I don't normally check where my nut attaches
post #5 of 7 (permalink) Old 01-28-2018, 08:05 PM
Location: Southern Maryland, Waldorf/LaPlata/Indian Head area
Too much info, OleDirtyDoc !
1985 700 Vulcan / Purchased 13,636 miles currently 19,126/Fork Seals & Dust Covers/Ignition Switch/AGM Battery/Hell Fire Windshield/River Roads Saddle Bags/Coil Relay Mod/2Wire Mod/RLU Bypass/Head Light Switch/Voltage monitor Green light/Mosfit R&R/Tuxedo Mod/Stator/Point Gap .020/ Dampers/Rear Signal & Brake Light LED'S/Rebuilt Shutoff Valve/Final Drive Gear Oil/Brake Shoes/Spline & Hub Lube/11 inch Progressive Shocks/De Goated/Engine Guard/Rejetted For K/N Pods/TOC mcct's
Sparkys73150 is offline
post #6 of 7 (permalink) Old 01-28-2018, 10:40 PM
WilliamTech3's Avatar
Thumbs up
LMAO !
Originally WilliamTech
Since May 2011
86 VN750 13,700 mi -Stock -Purchased 2008 w/8800mi
Jardine Fwd Controls, Custom Fenders w/Rails
Splines Lubed - 11/4/2012 - MF AGM Battery, Dampers went out @ 13+K !
...have a Vulcan good day !
WilliamTech3 is offline
post #7 of 7 (permalink) Old 05-28-2018, 01:43 PM
n2omike's Avatar
I use the Mobil 1 M1-110A It's black, and looks good. Also fits my daughter's Honda Accord. lol
05 VN750
Iridium Plugs
Spline Lubed front/rear
ignition pickups gapped
AGM Battery
Relocated MOSFET R/R
Coaster Mod
Pilot Screws at 2-1/4 turns
Slipstreamer S-08 Windshield
F&S Saddlebags/Mounts
Luggage Rack
12V Outlet
Mustang Seat
sissy bar
Oversized Pirelli Front Tire
6k miles
PW50, XR50, TTR90, XR100, DT175 (2-smoker), CRF230F, XR250R (dual sported), XR400R 4 KIDS, LOL!
1966 mustang street/strip
4-speed, nitrous
[email protected] 135.6
n2omike is offline
