01 vn750 ran hot, blown head gaskets - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 26 (permalink) Old 12-13-2017, 02:42 PM Thread Starter
Hi all, im a long time follower but this is my first post. I recently purchased a 01 vn750 for my wife that has been sitting for 4 years. So far Ive cleaned the carbs, cleaned the tank, done the pick up mod, a battery, and put in new iridium plugs. I was fixing a oil leak on the right engine cover when I discovered there wasnt a drop of coolant in the entire motor When I add coolant it immediatly starts dripping out between the head gaskets on both cylinders. Time to pull the motor....
I did run and ride the bike with no coolant in it, on the stand I ran it 5-10 minutes than took it for a short ride around the block, maybe another 10 minutes for the ride. Do you think I caused any irrepairable damage? The motor never acted hot or felt too hot to me.
I plan to pull the motor this weekend and order partz after I tear it down. Besides the head gaskets, should I order anything else?
01vn750892 is offline
post #2 of 26 (permalink) Old 12-13-2017, 10:06 PM
would you mind doing an introduction in the newbie section, please? thank you.probably didn't do any damage, if it didn't run hot,but it's hard to know for sure unless you rip her down
post #3 of 26 (permalink) Old 12-13-2017, 10:07 PM
while the motor is out it wouldn't hurt to do stator and balancer bushings
post #4 of 26 (permalink) Old 12-14-2017, 01:41 PM
If the motor didn't start making any noise or get too hot you'd probably be OK. These engines seem to run fairly cool, as long as you're moving anyways. Flush the oil.. if no metal particulates i'd say all good.
As mentioned, good time to address stator (they go out after 20-30k mi. less if you are unlucky,) and proactively change balance dampers.
post #5 of 26 (permalink) Old 12-14-2017, 02:38 PM
As someone who plans on splitting the case over the winter months, I also want to know "what else is needed".
So far this is what I think I'm going to need:
Things that should be replaced on a major/high milage teardown & reassembly
Head Gaskets (11004 x2)
balancers
stator
exhaust manifold crush gaskets x 2
clutch outside cover basket gasket (11060D right side of bike)
clutch cover gasket (11060B right side of bike)
stator cover gasket (11060A left side of bike)
transmission cover gasket (11060C left side of bike)
cylinder base gasket (11060 x 2)
Things specific to my rebuild
shift pawl oil seal (92049-1559)
Things I don't think I need to replace but should I?
valve cover gasket (11009)
What are other people's experiences with splitting the cases? Are all gaskets write-offs and need to be replaced? Do you guys generally make your own out of a sheet of gasket material (if so, are there any special considerations regarding oil/coolant/temperature) except for the head gasket? Anyone ever tried making an annealed copper head gasket?
Are there any o-rings for the oil/coolant systems that are notorious for needing to be replaced?
thtanner likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #6 of 26 (permalink) Old 12-14-2017, 03:33 PM
Anything that's a paper gasket will break. Every time. Except when you want them to...
I like OE gaskets as far as paper ones go, they have done my well so far on my VNs.
post #7 of 26 (permalink) Old 12-14-2017, 05:14 PM
So... you're saying you'd buy rubber-fiber sheet instead of 'standard' gasket sheet?
Thorn is offline
post #8 of 26 (permalink) Old 12-14-2017, 06:39 PM
No, just saying that paper gaskets usually don't survive removal is all. The paper/wax gaskets OEM uses is just fine single use.
Whatever the OEM material is seems to work great. - if that's the name for it it's a winner.
post #9 of 26 (permalink) Old 12-14-2017, 07:47 PM
also, paper gaskets work great on highly machined surfaces.. nice and smooth mating surfaces.
less cleanly machined surfaces will need a cork, rubber, or other material that has more 'give' to it.
michiganteddybear is offline
post #10 of 26 (permalink) Old 12-14-2017, 08:22 PM
Awesome, thanks guys.
Thorn is offline
