one exhaust runs cooler - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By Spockster
post #1 of 8 (permalink) Old 09-30-2017, 03:57 PM Thread Starter
Not sure if this is related to my drivability problems though I'm sure it is. Working on the bike and ran it down the road and back, won't go over 35-40 mph, doesn't hesitate runs smooth. Got back and put my hand behind the right side exhaust and is hot(like you would expect) put my hand behind the left side and it's cool, not hardly even warm. Ahhhhh..........
richny is offline
post #2 of 8 (permalink) Old 09-30-2017, 07:09 PM
Fuel, spark, compression, and timing.
Probably a dirty carb.
OleDirtyDoc likes this.
post #3 of 8 (permalink) Old 09-30-2017, 09:57 PM
yup yup
post #4 of 8 (permalink) Old 02-10-2018, 02:42 PM
Did you solve your problem. I have the same issue.
Johnboy99 is offline
post #5 of 8 (permalink) Old 02-11-2018, 08:37 AM
Wondering if you found your problem. My 99 this year started the same way.
post #6 of 8 (permalink) Old 02-11-2018, 09:14 AM
ubertalldude's Avatar
Have you done anything for the carbs, like cleaning them or running a carb cleaning fuel additive to the gas? That would be my first step, maybe even drain the fuel from the carbs and re-fill them with straight seafoam for a day or two, then drain and see if it'll run right.
ubertalldude is offline
post #7 of 8 (permalink) Old 02-11-2018, 02:30 PM
Probably stuck float or dirty carb. Seems to always be on the left side, same side the bike leans on the kickstand. Thats why I put it up on the center stand when I don’t ride for long periods.
post #8 of 8 (permalink) Old 05-28-2018, 10:21 AM
nhsmoker's Avatar
I would duuble check the spark make sure it is strong enough my sons vulcan 800 was doing this and I confirmed spark but apparently while sparking it was too weak. Changed his plugs and now runs like a top
nhsmoker is offline
