Carb adjustment after muffler mod - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-28-2017, 07:47 PM Thread Starter
Heckler94's Avatar
What kind of an adjustment needs to be done to the carbs after removing mufflers? I dont wanna burn valves up. I havent done the mod yet, but I plan on doing so this winter.
Heckler94 is offline
post #2 of 4 (permalink) Old 09-28-2017, 09:58 PM
are you doing the ear shave and the mufflers at the same time and what are you using in place of the old mufflers?
post #3 of 4 (permalink) Old 09-28-2017, 11:40 PM
If you open the pipes a lot, you should expect to need at least a larger main jet.
These carbs don't stay on the pilot jet very long, but a larger pilot may depend on what sort of transition you get from pilot to main.
I would read the plugs now for a baseline, and after the pipe mods. Jetting correctly can be tedious and time consuming to get just right. A 140 main may be a good start, again, depending how wide open you go.
post #4 of 4 (permalink) Old 09-29-2017, 09:13 AM Thread Starter
Heckler94's Avatar
Yes, Doc, I plan on doing the ear shave and the muffler mod this winter. I wasnt sure how much of a difference it would be for the carb adjustment after muffler removal. I have the tools and etc to tune carbs and such.
