Eng swap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 09-06-2017, 08:25 AM Thread Starter
Eng swap
I have a 2001 Vulcan 750 I need to know if it's possible to swap the engine with the 900? Well the 900 bolt into a 750 frame? Thanks in advance
Albert Sandman Sanders is offline
post #2 of 6 (permalink) Old 09-06-2017, 08:55 AM
nope.not a bolt in.what is wrong with the 750 that you would want to do this.oh,and would you mind doing an introduction in the newbie section? thank you
post #3 of 6 (permalink) Old 09-06-2017, 11:08 AM
anything is possible with enough $ and work.. but as mentioned, not a bolt in. if ease of swap was distance between 2 different states, I would put it somewhere around distance between florida and alaska.
it would require extensive re-engineering the frame to fit the 900, they are totally different engines.
Now, if you were swapping a vulcan 750 engine for a vulcan 700, thats a drop in swap
michiganteddybear is offline
post #4 of 6 (permalink) Old 09-06-2017, 12:59 PM
would need New swingman as well as the 900 is belt driven and the 750 is a shaft
post #5 of 6 (permalink) Old 09-06-2017, 01:15 PM
ubertalldude's Avatar
I'm thinking of doing a shoddy electric conversion if the motor ever goes out, but fitting a VN900 engine in this frame is gonna be a big chore. My friend has a VN900, nice comfortable bikes with good torque, but I don't think the VN900 engine would be an improvement, honestly. It doesn't rev as high and doesn't make as much HP, even though it does have better low-end torque. VN750 is all about revving to the moon and pinning down corners too tight for other cruisers, IMO. At least, that's what I like mine for. I dunno if the VN900 engine would be as satisfying in those regards.
ubertalldude is offline
post #6 of 6 (permalink) Old 09-06-2017, 01:54 PM
nope.that was basically gonna be my next post.
