Vapor/smoke from right pipe - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 9Likes
  • 1 Post By hayflana
  • 2 Post By Knifemaker
  • 1 Post By shark88
  • 2 Post By hayflana
  • 1 Post By ubertalldude
  • 1 Post By Sparkys73150
  • 1 Post By Thorn
post #1 of 9 (permalink) Old 08-16-2017, 05:48 AM Thread Starter
hayflana's Avatar
Hey guys. I just finished rebuilding my vulcan. I split the case because the linkage was broken. Anyway upon test driving it, i notice that after I turn it off, smoke/vapor gently comes out the RIGHT tailpipe ONLY. Any ideas?
Edit: forgot to mention that I put some engine oil on/around the piston head during re assembly so it wouldnt have to run dry too long. But Im pretty sure it wouldve burned away by now? Iv ran it several times now.
OleDirtyDoc likes this.
Hayden
hayflana is offline
post #2 of 9 (permalink) Old 08-16-2017, 10:46 AM
Well if the oil got blown into the exhaust, it might take awhile for it to go.
If the bikes on the side stand...vapor will rise and exit the right pipe.
As long as the bikes running well and the front and rear plugs look good, I wouldn't worry about it.....
shark88 and OleDirtyDoc like this.
post #3 of 9 (permalink) Old 08-16-2017, 10:02 PM
Good job getting it back on the road, now ride the Hell out of it!
post #4 of 9 (permalink) Old 08-17-2017, 01:51 AM Thread Starter
hayflana's Avatar
After riding it all day, the smoke is gone. Just some residule oil left in there I assume. And yea I am already riding the heck out of it! Thia is actually my first motorcycle. Im 18 and I willingly purchased this vulcan knowing that I would go through hell and back tearing it apart to fix the linkage! Im pretty proud of myself, I had alot of doubts during the whole process but managed to get this thing back in one peice and running again. Drove it to work today and WOW its so smooth. Shaft drive is just a dream to drive on! Ill add some pics of the final product.
ID:	40553   Click image for larger version
OleDirtyDoc and ubertalldude like this.
Hayden
hayflana is offline
post #5 of 9 (permalink) Old 08-17-2017, 09:02 AM
ubertalldude's Avatar
great work, man. splitting the case is no small task, and all for a first bike!
you'll ride it proudly knowing it runs because YOU fixed it with your own two hands.
ride on, brotha!
ubertalldude is offline
post #6 of 9 (permalink) Old 08-17-2017, 09:16 AM
Location: Southern Maryland, Waldorf/LaPlata/Indian Head area
Congratulations! You have every reason to be proud. We all start out just wanting to ride, but it's so rewarding to say, when i got my bike it wouldn't run an I fixed it! Look at the knowledge you have gained, and the good part is, no one can take that away from You!
Ride safe.
1985 700 Vulcan / Purchased 13,636 miles currently 19,126/Fork Seals & Dust Covers/Ignition Switch/AGM Battery/Hell Fire Windshield/River Roads Saddle Bags/Coil Relay Mod/2Wire Mod/RLU Bypass/Head Light Switch/Voltage monitor Green light/Mosfit R&R/Tuxedo Mod/Stator/Point Gap .020/ Dampers/Rear Signal & Brake Light LED'S/Rebuilt Shutoff Valve/Final Drive Gear Oil/Brake Shoes/Spline & Hub Lube/11 inch Progressive Shocks/De Goated/Engine Guard/Rejetted For K/N Pods/TOC mcct's
Sparkys73150 is offline
post #7 of 9 (permalink) Old 08-17-2017, 11:05 AM
Congratulations on a job well done. Jump into the deep end and you learn to swim fast, eh?
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #8 of 9 (permalink) Old 08-17-2017, 11:26 AM
nice job.
post #9 of 9 (permalink) Old 08-17-2017, 11:53 AM Thread Starter
hayflana's Avatar
All the positive posts mean alot guys, thank you. I can say for a fact that I know this bike all too well now ha!
Hayden
hayflana is offline
