Coolant Drain Bolt Threads Stripped - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
post #1 of 11 (permalink) Old 08-12-2017, 03:37 PM Thread Starter
Vulcan757's Avatar
So this weekend I'm trying to tackle everything that's wrong with my bike. PO really messed this bike up. I noticed a leak at the coolant drain bolt, and saw that the bolt wasn't tightened all the way in. So I went to tighten the bolt and coolant began to seep out fast. I ended up just taking out the bolt, draining out the coolant, and see that the female threads are stripped. Not too sure what I should do about this.
2006 Vulcan 750 - 30k miles
Vulcan757 is offline
post #2 of 11 (permalink) Old 08-12-2017, 03:38 PM Thread Starter
Vulcan757's Avatar
Picture for reference as to the bolt I am talking about.
post #3 of 11 (permalink) Old 08-12-2017, 03:45 PM Thread Starter
Vulcan757's Avatar
http://imgur.com/a/YMett
post #4 of 11 (permalink) Old 08-12-2017, 04:34 PM
Not sure if that's metal or plastic there. If it happens to be brass, you might re-tap it larger, use a larger bolt. I thought all the radiator drain bolts were plastic. ??? But I know some have broken those and replaced with metal.
First thought is JB Weld the bolt back in and drain it from the hose in the future.
post #5 of 11 (permalink) Old 08-12-2017, 05:00 PM
Location: Southern Maryland, Waldorf/LaPlata/Indian Head area
Hey, It's not magnetic, aluminum, or plastic, X2 re-tap, or JB weld and disconnect the hose to drain. I was lucky my drain plug was plastic, I was able to just replace the plastic plug. Maybe you can use teflon tape or get a new plug, and use teflon tap. Sparkys73150
1985 700 Vulcan / Purchased 13,636 miles currently 19,126/Fork Seals & Dust Covers/Ignition Switch/AGM Battery/Hell Fire Windshield/River Roads Saddle Bags/Coil Relay Mod/2Wire Mod/RLU Bypass/Head Light Switch/Voltage monitor Green light/Mosfit R&R/Tuxedo Mod/Stator/Point Gap .020/ Dampers/Rear Signal & Brake Light LED'S/Rebuilt Shutoff Valve/Final Drive Gear Oil/Brake Shoes/Spline & Hub Lube/11 inch Progressive Shocks/De Goated/Engine Guard/Rejetted For K/N Pods/TOC mcct's
Sparkys73150 is offline
post #6 of 11 (permalink) Old 08-12-2017, 05:16 PM Thread Starter
Vulcan757's Avatar
Can I just fill the hole with JB weld?
post #7 of 11 (permalink) Old 08-12-2017, 05:46 PM
Not sure, that might work, but I feel it would have a better chance of hanging on with the bolt in there. A large wad of JB may not cure well or hold as well. I'd go with the 24 hour formula, not the JB Quick. (15min)
One thing, it all has to be absolutely clean. I would clean it with acetone, paint thinner, turpentine, something like that.
I used JB to glue chunks back into the crankcase on a quad, the was in the 80s and it's still holding.
You do want to be sure it's holding, running over all that antifreeze would not be fun.
post #8 of 11 (permalink) Old 08-12-2017, 05:51 PM Thread Starter
Vulcan757's Avatar
Thanks Sprockster!
post #9 of 11 (permalink) Old 08-12-2017, 06:00 PM
Thanks Sprockster!
You're welcome .....
If the threaded fitting in the radiator is metal, I would seriously consider re-tapping it.
The thought of a bike releasing it's fluids on the road concerns me, already been down because of that. I was wrapped up like King Tut for a while.
OleDirtyDoc and Vulcan757 like this.
post #10 of 11 (permalink) Old 08-13-2017, 09:04 AM
I got a used radiator in good shape $20 plus shipping.i got paypal.
brock nevermore is offline
