engine out for stator replacement. Anything else to change? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By ubertalldude
post #1 of 8 (permalink) Old 07-10-2017, 01:51 PM Thread Starter
Bought a 2e vn750 friday 7-7-2017. for my self 89
i paid 400 euro and it game with a lot of new and used parts.
includes new stator, new R/R new MCCT 2x gadget for the stator cover.
The battery was not charging and the stator has shorted.
So i removed the engine.
Started yesterday and to day after work i got the engine out for stator replacement.
I will als replace the ACCT with the 2 new MCCT.
Can anyone advise me to change something else now the engine is out?
When it is in good running order i will sell my HONDA CBR1000F 94 and than i will have 2 vn750's one for my wife and one for mee
mvdijck is offline
post #2 of 8 (permalink) Old 07-10-2017, 01:53 PM
Balance dampers!
post #3 of 8 (permalink) Old 07-10-2017, 02:21 PM Thread Starter
Originally Posted by thtanner View Post
Balance dampers!
need a good link. I don not now where the are and how to replace.
mvdijck is offline
post #4 of 8 (permalink) Old 07-10-2017, 02:33 PM
Do yourself a HUGE favor and modify the stator cover to allow it to be serviced next time "without" needing to remove the engine. For less than $100 and a little extra work / effort on your part (see link below), this is a no brainier must while the engine is off the frame.
VN750 Stator Plate LC
1993 Vulcan 750 "T'Pol"
Cobra Full Exhaust (Single Sided)
M/F AGM Battery
NGK Iridium Plugs
Shinko 777 Tires
Sunpie 7" LED Projector Headlight / KZ750-B 76-79 Bucket & Trim
Full LED Bulb Conversion
Mustang Wide Regal Seat
Aftermarket Grips & Mirror's
Full Chrome Tach / Speedometer
Mobil 1 75-90 Synthetic Gear Oil
Rotella T6 / Bosch 3323 Filter
Iceshot is offline
post #5 of 8 (permalink) Old 07-10-2017, 02:54 PM Thread Starter
ok, do i have to remove the right side cover also? Or on the left side only the stator, the rotor and then the left hand balancer gear?
put in the 6 dampers and put it back?
mvdijck is offline
post #6 of 8 (permalink) Old 07-10-2017, 03:16 PM
just crushing along
meathead1465's Avatar
when you pull off the stator and the big cover behind it there is the flywheel and the gear to the left of that is where the dampers are.
the gear in the picture is just to the left of the flywheel and it is left handed bolt holds it on
meathead1465 is offline
post #7 of 8 (permalink) Old 07-10-2017, 03:18 PM
ubertalldude's Avatar
Good link for you in my signature (look for "dampers") which has all the parts you'll need to replace while you have it apart.
Iceshot, the tuxedo mod is a lot more than a lot of people are willing to do. I didn't do it on mine while I had the factory stator out. It might be worth listing the potential risk and difficulty of the mod when recommending it rather than saying it MUST be done
Even doing the balance dampers isn't a NECESSARY job, but it is a ridiculously good idea considering the cost and potential time savings. I have a hard time saying the same about the tuxedo after seeing how many people on here have had misalignment issues which ate the stator/rotor. Just my 2 cents
thtanner likes this.
ubertalldude is online now
post #8 of 8 (permalink) Old 07-18-2017, 12:12 PM
hmrct's Avatar
What he said. Tolerances *are* pretty tight. Even so, it's definitely possible to do the tuxedo mod properly as long as one is patient (anal?) enough to do the job *correctly*. The odds of success improve significantly if you purchase the parts you don't feel comfortable about fabricating. At an absolutely minimum, I'd recommend purchasing the steel plate rather than trying to roll your own: if the holes aren't drilled correctly, or the steel you elect to use is too thin, or, or, or, etc., etc., ad nauseum.
hmrct is offline
