squeal bottom left of egine 86vn750 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 2 Post By kc2dgq
  • 1 Post By Spockster
post #1 of 4 (permalink) Old 06-30-2017, 09:30 PM Thread Starter
Refeal
So i have been fixing some wiring issues on my 86 vn750. I had it on its center stand, had been started and running a couple times minutes before. i go to start it again after playing with the neutral switch wire. it all of a sudden is extremely hard start once it does start low idle allot of hesitation and wierd squealing from the bottm left of engine stator case area !!! shut bike down right away. is it engine ? or stator issue? did i spin a bearing ?
Laefer Lewis is offline
post #2 of 4 (permalink) Old 07-02-2017, 10:31 AM
I hate to say this but you may have a bad balancer damper gear. If this happens, the large gear in the left side of the case becomes loose enough to start rubbing and chewing up the inside of the front part of the left case cover...hence the squealing and additional resistance to motor turning over.
I would look into it....dampers are only around 50 bucks, most of the work is labor.....pulling or at least tilting the motor, pulling the side case and removing the gears to replace the rubber dampers. I did this myself last year.
OleDirtyDoc and thtanner like this.
post #3 of 4 (permalink) Old 07-02-2017, 10:54 AM
I agree with KC. Should see some black and silver debris in the oil screen.
OleDirtyDoc likes this.
post #4 of 4 (permalink) Old 07-02-2017, 01:35 PM
yup,sounds like balancer bushings
OleDirtyDoc is online now
