Coolant reservoir hose. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-13-2017, 08:10 AM Thread Starter
I was just installing new mcct's and ran into a problem.
I had the coolant reservoir out but still connected. But when I was about to put it back in, the top hose came loose. It's attached to the reservoir but I can't figure out where the other end goes. I can't see any place that fits the bill and Google turned up nothing.
Where does it go?
Biking Viking is offline
post #2 of 4 (permalink) Old 06-13-2017, 09:12 AM
ubertalldude's Avatar
The upper hose doesn't go anywhere, it's the overflow hose so just make sure it's pointing down towards the ground
ubertalldude is offline
post #3 of 4 (permalink) Old 06-13-2017, 10:31 AM
the lower hose goes up to the fitting just under the radiator cap.
post #4 of 4 (permalink) Old 06-13-2017, 11:53 AM Thread Starter
That explains why I couldn't find a spot for it.
Thank you.
