cooling fan - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 05-20-2017, 05:36 AM Thread Starter
cooling fan
I have a problem on my cooling fan switch. I need to fix it properly but for now I am going to cheat.
There is a small yellow wire that hooks up to the temp switch at the bottom of the radiator. I have to unplug that to get the fan to shut off. so I want to put a switch inline with that yellow wire so I can turn the fan on and off manually.
Where does that wire go? I need to find a place where I can tap into that line to place a switch.
Amy help would be great.
Blessings!
Richard
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 2 (permalink) Old 05-20-2017, 12:27 PM
mayor of Narnia
minikrew's Avatar
the yellow wire go's to the negative side of the fan
new supetrapp mufflers
led turn lights
talked to wolfie got highway pegs
to late to bring back wolfie now ride on brother
degoated
new rear drive & splines lubed h-pipe installed riding on the darkside
minikrew is offline
