Straight pipes and performance. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-12-2017, 07:35 AM Thread Starter
Hey guys.
I would like to get a slightly meaner sound out of this thing, so will be changing the exhaust.
Currently I am waiting for a "new" set of headers to arrive. The plan is to remove the original, including goats belly and simply run the header from the rear cylinder under the bike to the right hand side. I'm considering ending it in two 17 inch turn-out straight pipes with 8 inch baffles.
Assuming I do the headers properly and get them the same length, how much would this harm performance? Would the baffles provide adequate back pressure? And would a "balance pipe" provide any benefit?
Biking Viking is offline
post #2 of 6 (permalink) Old 04-12-2017, 11:04 AM
Might lose some low end torque, and you might need to re-jet the carbs, after reading the plugs. The baffles will help on both. Just how much, I'm not sure.
post #3 of 6 (permalink) Old 04-12-2017, 11:09 AM Thread Starter
How about a 2-into1 setup? Same style pipes but perhaps a slightly larger diameter.
post #4 of 6 (permalink) Old 04-12-2017, 11:17 AM
Can't say for sure, but anytime the exhaust is opened up, fuel mixture will lean out to some degree.
post #5 of 6 (permalink) Old 04-12-2017, 03:04 PM
It's really a lot of guessing unless you slap it on a dyno to properly read the a/f mixture, and tune accordingly. It's lean from factory, anyways, so opening the pipes up probably will affect that more.
post #6 of 6 (permalink) Old 04-12-2017, 06:17 PM
Know-It-All White-Trash
well to rejet the carbs for custom pipes it will be trial and error. if you buy aftermarket pipes made for vn750s you can order the jets on ebay that fit your pipe.
"Spock2.2" 3 clutches,3 engines, FK TUX MOD! Clubman bars w/ trimmed lines, Progressive shocks, FLO filter, gages app, RAM mount, custom light and signals. UV lights(antifreeze box and socks glow),(Jetted) V&H pipes, Brisk 360, Kuryaken HWY pegs (leg indifference disability), Viking bags, wet ears, Oil temp cap, Mosffet r/r under saddle bag. [email protected] 530ft 1/2 throttle 5th gear. i am alive because they see me, they hear me! I can downshift as fast as I can get the hell outta the way!
Damon FTW is offline
