Engine hot on the highway, already bled coolant - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 04-03-2017, 11:03 AM Thread Starter
Exclamation Engine hot on the highway, already bled coolant
Hey, my bike is getting pretty hot even when riding on the highway.
Yesterday there was a small leak from the right coolant tube going into the engine block. I tightened the hose clamp and everything was okay. Right after I was riding at around 60-70mph when I saw the temperature gauge slowly creep up from about 1/4 of the way up to halfway, then almost 3/4. Getting off the highway and going 30-40mph resulted in the gauge sticking around 3/4 and a little above that, almost in the red. I didn't see any steam coming out.
Coolant levels are okay, I changed the coolant about a month ago and properly bled the coolant system. Just to make sure there wasn't any air in the system I bled it again this morning. I can't see any coolant leaking out, there's definitely enough coolant in the system and overflow tank. I'm really at a loss.
P.S. I changed out the radiator for a used one off eBay about 2 months ago since mine leaked. It's in good shape
'86 VN750
snoopyonderdonk is offline
post #2 of 14 (permalink) Old 04-03-2017, 11:32 AM
ubertalldude's Avatar
Did you do anything with the thermostat while you had it apart? Seems strangely suspect that this is with fresh coolant and a radiator. Maybe a radiator flush might be in order? Good chance of crud deep in the fins, especially with is being a used unit.
ubertalldude is offline
post #3 of 14 (permalink) Old 04-03-2017, 11:38 AM Thread Starter
No, I kept my old 'stat in there. I've been reading about replacing it with a failsafe 160 degree thermostat from an '89 honda accord, maybe that would help? I'm not sure what the stock temperature is for our thermostats though.
When I replaced the radiator I spent a good couple of minutes blasting water through the system from a garden hose until it came out clean so I'm not sure if using radiator flush would help...
'86 VN750
post #4 of 14 (permalink) Old 04-03-2017, 12:05 PM
Yeah, if you have an '86 I wouldn't trust a 31-year-old t-stat, even if only OEM I would replace it. Sticking closed would definitely cause this, as could a clogged up radiator. If you flushed the engine coolant passages with hose water that's good, but there is a chance the radiator itself is sludgy on the inside, which could cause issues (not my first guess, though.)
I would probably go for a thermostat first and foremost, unless others on this site might have more insight. (Never done any cooling stuff on these bikes but did just do a massive cooling system overhaul on my '92 Pathfinder. Different beasts, but cooling systems aren't all that different from one vehicle to another)
post #5 of 14 (permalink) Old 04-03-2017, 12:12 PM Thread Starter
Thanks for your help. I'll probably pick up that new thermostat from Autozone later today then flush everything out with that Prestone flusher.
'86 VN750
post #6 of 14 (permalink) Old 04-03-2017, 02:05 PM
I don't want this to sound stupid,but is the fan coming on?
OleDirtyDoc is online now
post #7 of 14 (permalink) Old 04-03-2017, 02:12 PM Thread Starter
Yeah the fan does kick on about halfway up the gauge. Though it wouldn't matter on the highway..
'86 VN750
post #8 of 14 (permalink) Old 04-03-2017, 02:19 PM
halfway is right where it should kick on.just thought I'd ask.
post #9 of 14 (permalink) Old 04-03-2017, 02:25 PM
Seems to point to a sticking thermostat. Assuming no air in system, rad not plugged.
I suppose the water pump impeller could be gone. I guess I would take the t-stat out, put it back together without it, and see if the coolant is circulating. Meanwhile, the t-stat can be boiled in a pan of water to see if it sticks open/closed, though not a conclusive test, sticking can be intermittent. But if it sticks once, it can stick again.
Not a fan of 160 stats, running too cool all the time creates several problems.
post #10 of 14 (permalink) Old 04-03-2017, 02:26 PM Thread Starter
I appreciate the thought, Doc. Hopefully this 160 thermostat will fix my woes
'86 VN750
