is it easy - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 11-26-2008, 10:26 PM Thread Starter
Smile is it easy
hi vulcaneers. i finally got my 94 on the road[phantom gas syndrome-bad battery-pluged up carbs-stuck throttle]now ican apreciate what agood bike it is-iguess thats what iget for jumping in head first.i would like to put some new pipes on[crusers vh]i am new to the world of motorcycle mecanics.how much of a pain would it be-can ido it myself[do i need to 'degoat'.do i need any extras that dont come with the pipes.thanx 4 all the advicein the past -great site-cool people-thanx again irish mike....::
irish mike is offline
post #2 of 5 (permalink) Old 11-27-2008, 01:09 AM
It should be rather easy. I got jardines and I had to use the right side header. I had to cut a piece off to make it fit. Be sure to replace the crush exhaust gasket if posible. Look up in the exhaust forum to find the gasket number. Gasket off of the harley fits. If I am wrong someone here will jump in and correct me. Hope this helps.
post #3 of 5 (permalink) Old 11-27-2008, 04:34 AM
750Doug's Avatar
If you install a set of aftermarket pipes, you will be "degoating" simply because it's removed and done away with when installing an aftermarket set.
VH, Cobras, Jardine pipe kits don't use the goat belly at all.
750Doug is offline
post #4 of 5 (permalink) Old 11-29-2008, 01:05 PM
claudio75's Avatar
I confirm: I replaced the mufflers with Cobra, and have to remove the goat belly. The gaskets were included in the Cobra kit. After burning a pair of trousers, I Put back in place the old heat shield...
I also had to put some ceramic wool inside the Cobra, to avoid getting a fine with the noise...
93 VN / marbled / degoated /Cobra mufflers / MF battery / Iridium plugs
California windshield /changed handlebar/ foam handles/
All bulbs changed with leds / RR changed and relocated
(right cover) / Daelim top case with home made supports.
claudio75 is offline
post #5 of 5 (permalink) Old 11-30-2008, 10:15 AM
Search Goddess
Dianna's Avatar
Since the goat's belly is removed you will probably have to fashion a center stand stop so it doesn't slam against your new pipes. Some come with a rubber stop (V&H's ) some don't.
Dianna
Conway, AR
Patriot Guard Rider
2000 VN750 Sere (Serendipity)
1990 GL1500 (Ole Blue)
VROC # 11628 / 25000-H
OKVROC # 18 (H)
TNVROC # 45 (H)
Dianna is offline
