Red Lining - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 09-27-2005, 05:21 PM Thread Starter
Red Lining
Hi,
I've just noticed my 2002 VN750 (only had for a couple of weeks) thermostat climb up to the 1st red line while i was sitting idle talking to someone, I immediately took off and the bike cooled down as soon as I started moving, my radiator res if completely full. I was just wondering if its normal for the bike to hit the red line because I am planning to ride it in to work and I do not want any engine damage from overheating at stoplights, Thanks for any input
Al
Alkb is offline
post #2 of 14 (permalink) Old 09-27-2005, 11:41 PM
Re: Red Lining
Hi Al,
My wife and I just bought 750's and I also ride a 1500 Vulcan water cooled and the one thing that comes to my mind is how old is the coolant? If it's not fresh I would change it. Keeping fresh coolant will make a difference for cooling. If you do change it and still notice the temp gauge rising...then I would look at the thermostat next. Just a couple of ideas.
whistle clean is offline
post #3 of 14 (permalink) Old 09-28-2005, 10:31 AM
Loran in Npvl IL's Avatar
Re: Red Lining
Getting to the red line is not normal.
If you are stopped, you should also be able to listen for a fan kicking in. If you do not here the fan then that could be why the bike is heating up
Deuce (Loran Naperville IL)
2003 VN750
- Corbin seat w backrest
- Progressive suspension.
- Kury iso goldwing grips
2 1983 V65 Magnas
Loran in Npvl IL is offline
post #4 of 14 (permalink) Old 09-28-2005, 01:23 PM
Re: Red Lining
Check you fan and ensure that it is working properly. That is the only thing that will stop the temp from climbing while stopped.
lazydog is offline
post #5 of 14 (permalink) Old 09-29-2005, 03:30 PM Thread Starter
Re: Red Lining
My fan does kick on, i dont know if it only kicks on at certain times but i know when i park and get off, the fan is going. I rode it in to work today (bout an hour trip) and it barely got past the midway point but i didnt have to sit at lights very long either and it was also only a nice 80 degrees this morning. It seems that while i am moving the bike will stay cool, I just noticed it climbed up to the 1st red line a couple of days ago while sitting in nuetral in texas heat for about 10 minutes (bike was already hot) but as soon as i took off it cooled down. I've put new coolant in and also realized there was entirely too much oil in the bike so I drained and put the appropriate amount in (can actually see a line in my window now). I dont know if having the oil filled up too high can cause problems or not but im willing to try anything at this point. Is there any further troubleshooting I can do to make sure everything is working? Thanks again,
Al
Alkb is offline
post #6 of 14 (permalink) Old 09-30-2005, 04:26 PM Thread Starter
Re: Red Lining
Hey Again,
Well I just noticed my coolant resevoir is completely empty so im assuming I have a pretty nasty leak somewhere. I will search around and see if I can find anything leaking, thanks for the help
Al
Alkb is offline
post #7 of 14 (permalink) Old 10-01-2005, 04:30 AM
Now what
Ironman's Avatar
Re: Red Lining
Originally Posted by Alkb
Hi,
Al
No, that's not normal at all. The fan should kick in just after the needle passes the half way mark. If it's working (and it sounds like it is) I'd make sure all the air was out of the system by using the bleed valve that's located either on the thermostat housing, or near it.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #8 of 14 (permalink) Old 10-01-2005, 11:42 AM Thread Starter
Re: Red Lining
Hello Again
Another update, Appearantly im a moron there is no leak in my system the bike was just hot, whenever it cooled down the res was full again. I have checked the fan and it does come on at the halfway point on the temp guage. Where might I be able to find the thermostat on my bike? Thanks again
Al
Alkb is offline
post #9 of 14 (permalink) Old 10-01-2005, 12:01 PM
Re: Red Lining
Al,
Before you tear into the thermostat I would follow Ironman's suggestion and do a check of your coolant.
You'll need to remove the radiator cap (only when bike is completely cooled down) and see how much coolant is in the radiator. If it needs more then add it slowly until it is full ( Honda makes a 50/50 mix that works well). Also be sure that when you do this that the coolant in the overflow tank is at the correct level (between low and full level as marked on the tank cover). If you needed to add coolant you'll then need to release any air that may be trapped inside of the radiator and to do that you'll have to remove the gas tank to get to the housing where the release bolt is located (at the thermostat housing). If you do not have a manual I highly recommend that you buy one so you can see and follow the steps outlined in the manual so you do it correctly. If after you check / add coolant...and release any trapped air in the radiator...and the engine still overheats...then I would take a look at the thermostat next. Just my thoughts.
post #10 of 14 (permalink) Old 10-02-2005, 10:28 AM Thread Starter
Re: Red Lining
Thanks guys I've ordered a Clymers service manual will let you know the outcome after I get it
Al
Alkb is offline
