Getting real hot even when riding - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 02-28-2017, 07:09 PM Thread Starter
Question Getting real hot even when riding
Hey guys, just got a new radiator installed for my '86 rebuild project. I've been riding her around lately and noticed that she likes to stay a little toasty. I'm talking about 3/4 up on the temperature gauge. Even when the bike is moving 60 mph, the gauge still sticks high. Any ideas?
I'd like to note too that I haven't been able to test out the cooling abilities yet until that new radiator came in, the old rad had a crack in it causing antifreeze to leak.
Also the fan kicks on as intended when the bike isn't moving
'86 VN750
snoopyonderdonk is offline
post #2 of 9 (permalink) Old 02-28-2017, 07:40 PM
jgs000's Avatar
Location: elmira ny, great place to ride, no jobs though
should run near the first two marks on the gauge, when it goes above that the fan should come on even if you riding. running the bike too lean will make that gauge run in the middle. check to make sure your plugs are not white, light brown is ok but the bike will run hotter, I like to have the plugs a dirty looking brown, runs cooler but not as fast. I get over 40 miles per gallon but at 45-50 mpg might be on the lean side. somebody posted about seeing the coolant move under the cap when its running but i'm not sure how to do that
jgs000 is offline
post #3 of 9 (permalink) Old 02-28-2017, 09:11 PM
did you bleed the system?
post #4 of 9 (permalink) Old 02-28-2017, 10:50 PM Thread Starter
I did not. Will air in the system really cause that big of a temperature difference? Also I read up on it today and I'll definitely be bleeding it first thing in the morning, i'm just curious
'86 VN750
post #5 of 9 (permalink) Old 02-28-2017, 10:53 PM
like any hydraulic system,fluid does not flow properly with air trapped in it
post #6 of 9 (permalink) Old 02-28-2017, 11:03 PM
Air can cause big temp swings at the gauge. Warm it up and open the bleeder, you'll probably hear the air.
Normal temp on mine is dead in the middle of the gauge or slightly below. Up past 3/4 to the red, it's getting hot, as in the fan probably quit or it's low on coolant, never goes past halfway in hot weather.
post #7 of 9 (permalink) Old 02-28-2017, 11:31 PM
mine never went past half and the fan would never come on when it was moving.
post #8 of 9 (permalink) Old 03-01-2017, 12:07 AM
jgs000's Avatar
I'm wrong about the fan coming on when moving
jgs000 is offline
post #9 of 9 (permalink) Old 03-10-2017, 06:47 AM
1985 VN-700
L2fish's Avatar
running hot
Air does make a difference
L2fish is offline
