No Hand Controls - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 02-09-2017, 12:23 PM Thread Starter
Madmyk's Avatar
No Hand Controls
Bought an '85 VN700 last month that the previous owner started bobbing and then gave up. He did an ear shave and re-jet of the carbs, but only re-connected one of the throttle cables. He also threw on some Z bars, but didn't keep the original throttle grip. Couple questions:
1) the second throttle cable isn't necessary, right?
2) Having to start from scratch, could I use an HD setup for the throttle?
3) The choke is on the clutch side, does it need to be re-attached with the ear shave done?
Madmyk is offline
post #2 of 3 (permalink) Old 02-09-2017, 12:45 PM
hd throttle is for 1" bars,vn is 7/8".you can run with the pull cable.
post #3 of 3 (permalink) Old 02-09-2017, 03:25 PM
check eBay for throttle controls. yes you will still need the choke after ear shave.these bikes are cold blooded
