Help with waterpump - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 09-26-2016, 11:25 AM Thread Starter
Help with waterpump
I am fixing my sons 2002 750 Vulcan.I am replacing the mechanical seal and when I removed the impeller the seal was trashed.My Manuel (not the best) states that there is just the mechanical seal and the little o-ring at the end of the shaft.I miked out the seal and the coupling that it goes in and there is around a quarter inch from the bottom of the seal to the coupling.Does anything else go in there?From what my Manuel states that only a small O-ring and the mechanical seal and impeller go on the shaft.Thanks For your time,Tom Click image for larger version
debtom6153 is offline
post #2 of 4 (permalink) Old 09-26-2016, 12:33 PM
heaney750's Avatar
is the spring still on the the coupling? pics would help alot
heaney750 is offline
post #3 of 4 (permalink) Old 09-26-2016, 12:38 PM
heaney750's Avatar
it should look like the pic
post #4 of 4 (permalink) Old 09-26-2016, 07:54 PM Thread Starter
I got that seal and a new o-ring.The seal and the o-ring are the only thing that goes in front of the impeller?Thanks
