I need advice on removing a SUPER stuck stock muffler!!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
  • 1 Post By Chris and Shim
  • 1 Post By Spockster
  • 1 Post By michiganteddybear
  • 1 Post By JimmyMac
post #1 of 10 (permalink) Old 09-03-2016, 05:15 PM Thread Starter
Eagle Riders 4146
JimmyMac's Avatar
Perfect day to install the EMGO Turnouts I purchased a few weeks ago. Too bad the stock muffler isn't wanting to cooperate. It is super stuck! I've sprayed WELL with WD-40 Rust Release and let it set for a couple hours, hit it with a hammer, and rocked and twisted it. Still won't budge. I'm beginning to think I'll have to get the angle grinder out, and cut the header pipe before I start cutting the belly into pieces to get it out...then make the trip to the muffler shop to have a short length of pipe welded on so I can "slip on" the slip-ons. Any suggestions?
ID:	33914   Click image for larger version
[FONT="Palatino Linotype"][SIZE="5"][SIZE="2"][FONT="Comic Sans MS"]"Sometimes you find yourself in the middle of nowhere; and sometimes, in the middle of nowhere, you find yourself."[/FONT][/SIZE][/SIZE][/FONT]
[I]'03 VN750 aka "Shelley"
42K Miles
Purchased July '16
Oil Changed - Shell Rotella 5W40
Radiator Flushed - Engine Ice
EMGO 19" Turnout Mufflers
Super Start AGM MF Battery (220 CCA)
K&N Air Filters - No Ear Shave
Stay tuned.....[/I]
[SIGPIC][/SIGPIC]
JimmyMac is offline
post #2 of 10 (permalink) Old 09-03-2016, 05:28 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I don't have an answer for you other than liberal use of some sort of penetrating oil, which you've already tried. I, too, was trying to loosen my right side one yesterday but it was also stuck on just as solid as yours. It turns out I didn't even really need it moved so I'm fine and didn't experiment any more on getting it loose. Anyway, at least you know it's not just YOUR machine like that. Small consolation. Good luck to you.
JimmyMac likes this.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #3 of 10 (permalink) Old 09-03-2016, 06:43 PM
Heat.
Maybe ride a while to get everything hot, then hit the area that was clamped with a propane torch for a few minutes.
post #4 of 10 (permalink) Old 09-03-2016, 10:37 PM
just what I was gonna say, heat.. either from riding (not idleing, may not get the exhaust hot enough) for a bit, or hit it with a torch. if propane isnt hot enough, and you dont have an Oxy/Acetelyne setup, try MAP gas. its considerably hotter than straight propane
michiganteddybear is offline
post #5 of 10 (permalink) Old 09-04-2016, 09:55 PM Thread Starter
Eagle Riders 4146
JimmyMac's Avatar
Thanks Spockster and MichiganTeddyBear! I'll try riding first. I that doesn't work I'm sure I can find a friend with a torch. Having said that, is there a marked performance advantage to ripping out the belly and welding in a cross-pipe? If yes, I'm wondering if I should maybe go that route, and not even mess with trying to pull the stock mufflers. If I do de-goat, would that require adjusting/re-jetting the carbs?
42K Miles
Purchased July '16
Stay tuned.....[/I]
[SIGPIC][/SIGPIC]
JimmyMac is offline
post #6 of 10 (permalink) Old 09-05-2016, 08:26 AM
degoat will likely require jet changes. definately will if you have made intake modifications (ear shave).
post #7 of 10 (permalink) Old 09-06-2016, 01:50 AM Thread Starter
Eagle Riders 4146
JimmyMac's Avatar
Update: I went out today to give it another go. I sprayed more rust penetrant, and then banged some more on the connection. I followed that up with tapping a flat-tip screwdriver in several places between the muffler flange and pre-muffler pipe, and then did some gentle prying...followed by some twisting on the muffler. Voila! It came off! I buttoned it all up and then cranked her over. Wow! what a difference in sound between the stock muffler and the EMGO Turnout! I needed to get ready for work, and so I'll tackle the left side tomorrow. Here are a couple pictures showing the stock and the new EMGOs (Shelley needs a bath after running through a mud puddle.)
Here is a YouTube link showing comparison between the stock and EMGO Turnouts. I really like the sound and look! The only thing I'm not pleased with is the heat shield. The back side has a really large diameter for the stock exhaust. Does anyone know of a narrower heat shield that will work to give it a more aesthetic look?
EMGO TURNOUT SLIP-ON MUFFLERS VN750
Gaz73 likes this.
42K Miles
Purchased July '16
Stay tuned.....[/I]
[SIGPIC][/SIGPIC]
JimmyMac is offline
post #8 of 10 (permalink) Old 09-06-2016, 04:03 AM
Tinkerer
Gaz73's Avatar
sounds and looks good
Man can not live by bread alone... he needs Duct tape & WD40
Gaz73 is offline
post #9 of 10 (permalink) Old 09-06-2016, 05:20 AM Thread Starter
Eagle Riders 4146
JimmyMac's Avatar
Thanks, Gaz!
42K Miles
Purchased July '16
Stay tuned.....[/I]
[SIGPIC][/SIGPIC]
JimmyMac is offline
post #10 of 10 (permalink) Old 09-06-2016, 04:32 PM
Sweet?
Tags
belly , header , muffler
