Engine Running Bolts Spinning - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-11-2016, 09:38 PM Thread Starter
rad4u2's Avatar
Hi,
Can someone please look at this video and notice that as the engine revs up, the bolts/nuts are spinning. This is how I got the bike and it doesn't seem right that they are spinning.
1. Is this normal for them to spin like this or should they be tightened up?
2. There is one on the opposite side, are they connected together with one long bolt or are they two separate bolts?
3. What purpose do they serve? (Are the securing the engine, holding the frame together...etc..)
Thank you!
rad4u2 is offline
post #2 of 5 (permalink) Old 08-11-2016, 09:41 PM
Motor mount bolt.no it should not spin.is either loose or broken.should be straight through.just tighten
post #3 of 5 (permalink) Old 08-12-2016, 12:11 AM
Can't tell by video do both sides spin the same way?cause if they spin different ways its broken
post #4 of 5 (permalink) Old 08-12-2016, 11:59 AM
Expendable newbie
evulcannibal's Avatar
On the right side it spins CCW, left side spins CW.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #5 of 5 (permalink) Old 08-12-2016, 01:06 PM
Looks like it goes both ways on the left(yeah I said it)but need to know if they both spin the same.or try grabbing one side to see if other side stops.if it does,just tighten it up.if the other side keeps on spinning you have a broken bolt
