engine oil flow route - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-02-2016, 11:57 PM Thread Starter
Send a message via AIM to Inga Send a message via MSN to Inga
just wondering about how the oil flows throughout the engine. i see the starter shaft and gear are lubed by a constant engine oil flow so it looks like it goes back to the sump where the oil screen stops metal particles then on to the filter where it then goes to the crank and so on splashes the piston skirts goes up to the heads and down to the starter and back? just wondering. i looked on the TOC manual but nothing there.
Inga is offline
post #2 of 3 (permalink) Old 08-03-2016, 11:45 AM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
Go to the General Discussion section above and download a maintenance manual. The oil flow is in there, along with darn near anything else you'd want to look up.
Saddlebags, hard mounted
Fork mounted tool bag (now hard mounted)
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
National Cycles Low Boy Heavy Duty windshield
Home made lowers (nice)
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Light bar with LED lights
Progressive 412 shocks
Chris and Shim is offline
post #3 of 3 (permalink) Old 08-08-2016, 01:11 AM Thread Starter
oil flow route link
i downloaded the TOC manual but will not open,found this link-here it is @ dans m/c repair, scroll down it is near the bottom of page. Dan's Motorcycle Four Stroke Oil Flow
Inga is offline
